triple x markings on lifter valley - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 17 Old 05-08-2007, 06:57 PM Thread Starter
Question triple x markings on lifter valley
what does this mean? is it a good block to have for semi- hot motor? i know it is a non roller motor, it is out of a 84 gt, tore it apart for 4 collapsed lifters, going to re build it with good stuff, just wondering what triple x mean.
swifty84 is offline
post #2 of 17 Old 05-08-2007, 07:09 PM
LT1HAHA's Avatar
It means it is a stock block.....sorry but it's nothing special
91 Road Racing Fox. N/A 383W. Full MM setup front and rear with Bilstein coil-overs. 14x1.25 Wilwood 6 piston fronts with Wilwood 13x1 single piston rears.
486rwhp/ 430rwtq
LT1HAHA is offline
post #3 of 17 Old 05-08-2007, 07:14 PM
Ditto
2002 GT: Vortech T-trim, Paxton Intercooler, Full exhaust, 4.10's , Dragon Plenum/TB....
1993 Hatch: Forged 306 shortblock, Twisted Wedge heads, Stage 1 cam, BBK SSI Intake, full exhaust
reef93lx is offline
post #4 of 17 Old 05-09-2007, 05:26 AM
IND9S's Avatar
Trader Feedback: (29)
my factory stock block in my 92 was a xxx. hydraulic roller motor. from what i have seen building motors there were two designations on the factory 302 blocks. xxx up to 92 had forged pistons and yyy 93 only (i believe) hydraulic roller hypereutectic pistons. that is what i have seen but could be wrong.
1992 Mustang LX, Vortech Blown Renegade 317..
Originally Posted by huafist View Post
I'd drag my bare nuts through a mile of broken glass just to hear that girl fart through a walkie talkie.
IND9S is offline
post #5 of 17 Old 05-09-2007, 03:07 PM
Moderator
Ehardy1971's Avatar
Originally Posted by brad View Post
incorrect IND95.. yyy was not only 93 and hyper pistons.... please do not spread mis information...
this is correct!,I have a roller block that came out of an 86 cougar that has the YYY casting,and my current engine I'm building for my notch is a non roller(which I have converted to roller cam) 80 block that has XXX,so these codes don't mean what kind of slugs came in them!
'89 LX Coupe
GT40 306 with a few bolt ons and in the 12's
'01 Lightning
#6257 of 6381 Bolt ons, pulleys, and tuned.
'06 TBSS
K&N drop in, and Borla dual exhaust, for now.
Ehardy1971 is offline
post #6 of 17 Old 05-10-2007, 03:29 AM
the block itself is NO DIFFERENT.....
....XXX just means that there is no clothes on the stuff underneath....
.you have to look inside.
there is NO correlation to XXX or YYY or KKK or any of the viewed markings........!!!!
Kato Engineering is offline
post #7 of 17 Old 05-10-2007, 03:31 AM
EvilGooses's Avatar
XXX means its 3 times more likely to split down the middle than a Mex at 500 rwhp!
EvilGooses is offline
post #8 of 17 Old 05-10-2007, 03:35 AM
XXX means that it needs a DIAPER to keep from spewing oil all over the track when it splits down the middle....
it already has a GIRDLE...
and THAT does NOTHING but drain 100 dollars out of your walletttttttt.......................$$$$$$$$$$$$$$ $$$$
post #9 of 17 Old 05-10-2007, 03:58 AM
Banned Alleged Scammer
Trader Feedback: (155)
a $100 girdle is better than a $1500 rotating assembly.My friend split 2 blocks and the rotating assembly was still fine so girdles aren't as worthless as everyone says they are
post #10 of 17 Old 05-10-2007, 04:21 AM
it is better to just buy an EARLY block with the 100 dollars extra.....
post #11 of 17 Old 05-10-2007, 05:21 AM
BadAss88GT's Avatar
I thought all XXX, YYY, KKK, ABC blocks were late model roller blocks. How did this one come out of an early 80s?
Yes, a main girdle can save the rotating assembly. It can prevent it from falling out when the block splits. The valley girdle, which we've all seen spammed on this site, is a joke. We already have a valley girdle on every engine.
BadAss88GT is offline
post #12 of 17 Old 05-10-2007, 11:25 AM
bhleonard's Avatar
Trader Feedback: (54)
I've known main girdles to split and break WITH the block..
bhleonard is offline
post #13 of 17 Old 05-10-2007, 12:07 PM
Nutty 5.0's Avatar
I have a crappy sportsman FRPP 302 B50 block and also has XXX. No nekid anything inside!
93 GT Cobra clone - Sold Pics here:
http://forums.corral.net/forums/showthread.php?t=954071
I do installs. PM for details.
Nutty 5.0 is offline
post #14 of 17 Old 05-10-2007, 12:29 PM
Banned
Trader Feedback: (-1)
Triple x's, o's, y's ect... are just band aids casted on for the pit holes in the block.
post #15 of 17 Old 05-10-2007, 01:01 PM
kim
Moderator & USAF (Retired)
kim's Avatar
Thats because the B50 is nothing more than a stock block for "sportsman" racers. The original "sportsman" block offured circa 1997, was M6010A351 and designed around the roundy rounder classes. Similar iron as the N351 for NASCAR, but designed within stock block paramaters so it was available to the average Saturday night guys.
kim is offline
post #16 of 17 Old 05-10-2007, 05:46 PM
Sons88GT's Avatar
My 88 California block has XXX and YYY in the lifter valley..lol
88 GT, Best 11:26 @ 120.01 C4 By Silverfoxbody.
351 Cleveland 4V is here! Fear the Cleveland!
Sons88GT is offline
post #17 of 17 Old 05-10-2007, 06:12 PM
BadAss88GT's Avatar
... over at hardcore, the dizzy problem you were having..... my suggestion help any or have u found something else.... i would look on HC.. but they bann members that try and help...
Dunno, havent spoken to the guy that owns the car in a while.
