How many miles before your new motor is 'really' broken in? - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 22 Old 03-04-2007, 09:32 PM Thread Starter
Most builders say take it easy for the first 500 miles or so. But I'm wondering how many miles till a motor really comes into it's own? Just curious.
Jeff
Jeff U. is offline
post #2 of 22 Old 03-04-2007, 10:21 PM
Most of what needs doing is done within the first 1/2 hour of running. Warm it up a little, don't lug it, load it and unload it in gear, all through it's normal rev range. After a 1/2 hour of that you're good to go. She'll continue to loosen up a bit over the next few hundred but that critical bore seal is established, which is the main point of a break in.
P51C
P51C is offline
post #3 of 22 Old 03-04-2007, 11:55 PM
Clint Mumford's Avatar
WHEN I INSTALLED MY 408 FROM COAST HIGH PERF. THEY TOLD ME TO RUN IT FOR 20 MINUTES ON JACK STANDS, RUN THROUGH THE GEARS.....LET IT WORM UP. KILL IT.....LET IT COOL....DRAIN THE FLUIDS.....REFILL THE OIL, AND THEN RUN IT.
THINK ABOUT TOP FUEL CARS. THEY REBUILD THE ENGINE EVERY TIME, RUN IT TROUGH THE GEARS AND THEN GO BALLZ TO THE WALL.........
GOOD LUCK.
93' gt conv white (3440lbs with driver)
408 Windsor w/10.5:1
AFR 205's
FTI solid roller cam
1.6 rockers
EFI Spyder intake with 42lbs inj.
80mm Pro M
90mm TB with AFM 4in Power Pipe
1 7/8 KOOKS LT with 3" X pipe and Magnaflows
Electronics: MSD 6AL, TwEECer
Best time to date: 11.20 @ 121.14
Best MPH : 122.46mph
Clint Mumford is offline
post #4 of 22 Old 03-05-2007, 12:07 AM
jayman306's Avatar
brake it in like a wimp and it'll run like one......lol
just kidding.. i put mine on stands and warm it up and run it through the gears and let it coool then drain oil (replace it too) then do it again the next day.. seems to work for me.. ive doen 4 motors like this.. 2 chevy and 2 ford,nitrous n/a and s/c
FAST BY FILIPPELLO ALBANY,NY
jayman306 is offline
post #5 of 22 Old 03-05-2007, 06:54 PM
for those of u saying run it thru the gears. Do you mean redline it thru each gear or just shift at low revs like 2 or 3rpm?
89 GT full bolt ons - sold
88 LX 331 stroker, AFR heads, FTI custom cam, Edl Rpm 2 intake, Mahle pistons, Scat rods, Scat crank, 80mm MAF, Mac longtubes to exhaust, MSD Digital 6, spool, 4.10s
sbx213 is offline
post #6 of 22 Old 03-05-2007, 07:21 PM
I have always been taught 3 heat cycles. Let it warm up completely and cool completely three times. Change the oil. Then hammer down. How is a strip only car going to complete 500 easy miles?
1990 Notch
302, TFS Top End Kit, PA C4, 3800 Edge Converter, 150hp NX, UPR Pro Series Rear, 4.10's Moser axles
6.84 at 98.72 1/8 Mile Best, trying to get better weekly
nate-roth is offline
post #7 of 22 Old 03-05-2007, 07:27 PM
Trader Feedback: (40)
I would be careful comparing a top fuel drag car to a driver that spends 1000's of miles on the road, not burning oil.
Different parts, tolerances, etc. used for each.
I wouldn't compare longevity vs. a 1/4 mile at a time in this case.
Modular is offline
post #8 of 22 Old 03-05-2007, 08:04 PM Thread Starter
Most answers are indicating that it happens almmost immediately. I guess where I was going was...do all the engine components start to settle in and coming together any more at say 1000 miles compared to the first 100?
Sounds like no.
Jeff U. is offline
post #9 of 22 Old 03-05-2007, 08:30 PM
Michael Yount's Avatar
Assuming quality build, parts and machining - the rings will seat within minutes of start up. Be sure to prime the oil system so the start up isn't dry. Assuming good pressures, temps, no noises, no leaks - take it out and drive it. Vary the revs without really hammering it -- and taking it up to 4-5000 easily and then backing off helps seat the rings in. After a few heat cycles -- drain oil/filter. Then you're good to go. Drive it as hard (or not) as you like. With miles, things will continue to loosen up. Take a look at the performance data from the car mags that do long term tests. Almost always their cars are a few ticks quicker to 60, in the 1/4 and a couple of mph quicker on top end with 40,000 miles on them then when they're new. Also, probably best to use a non-synth oil for start up and for the first change or two. Amsoil wants you to wait til 5000 miles -- consult with your machinist -- how cylinders are finished and the ring choice dictates when the switch to synth can occur if you want to do that.
Michael Yount is online now
post #10 of 22 Old 03-05-2007, 08:44 PM
no power shifts for two days
beermoney is offline
post #11 of 22 Old 03-05-2007, 08:54 PM
MFE
Super Moderator
MFE's Avatar
I dyno'd my engine at about 500 miles, and it definitely "felt" looser than it did when I first got on it. In that 500 miles I didn't give it very high RPM but I definitely wasnt' shy about generating cylinder pressure and cylinder vacuum to seat the rings, with full-throttle bursts from 1500-4000 RPM and then off-throttle in gear decels. However when I took it back to the same dyno a few thousand hard miles later, it showed consistenly 10 more RWHP in quite similar conditions as before with no changes to tune or equipment.
MFE is offline
post #12 of 22 Old 03-05-2007, 09:54 PM
You need load to make the rings seal. Running it on jackstands ain't gonna provide that. Better to take it out and work it up and down the rev range a bit, like I said, then change the oil and filter and go for it.
P51C
P51C is offline
post #13 of 22 Old 03-05-2007, 10:03 PM
lx2gt's Avatar
i put my coast motor in, pulled out my driveway, drove it up and down the street a few times, i tried not to beat it for 500 miles but probably only got to 150 before full throttle pulls to the red line, raced it at 500 miles and had it tuned on a dyno at 700, it has 2500 now and runs great, burns no oil, no smoke,
90 notch, 347, 185's, 12.6 @ 110
66 coupe with mustang 2 front and a 4 link and 8.8 in the rear, coil overs all around with a 4.6L in the works
lx2gt is offline
post #14 of 22 Old 03-05-2007, 10:23 PM
Again -- talk to your machinist about the parts picked and the machining. About 17 million new engines a year are produced by the OEM's. They're fired for the first time, driven off the line and onto a truck and delivered to a dealer. The vast majority have no discernible break in treatment at all -- and they vast majority go on to produce 100k-200k-300k miles of reliable running usually with less maintenance than the folks in the threads are gonna give. If the right parts are picked, machinists know what they're doing and assembly is correct -- the rings are gonna seat within minutes of firing - whether it's on the jack stands or running up and down the street in front of your house. And if you don't get parts/machining/assembly right -- it won't matter much what you do.
post #15 of 22 Old 03-05-2007, 10:55 PM Thread Starter
Good info here. I have about 2000 miles on my rebuilt 302 and it feels slightly quicker now than when I first dropped it in. Was wondering if that was normal or maybe I'm imagining things. The butt-o-meter seems to think it's a little quicker.
Jeff
Jeff U. is offline
post #16 of 22 Old 03-05-2007, 10:58 PM
Yup - they loosen up....
post #17 of 22 Old 03-06-2007, 03:29 AM
Stephen Johnson's Avatar
I just refreshened my 331 and it has 180miles on it and it smokes. My first 331 smoked for a couple hundred miles and then finally quit. I have heard take it on the interstate and run up to 65mph and left off, then again, like 5-6 times and that will help ring sealing. I may try changing the oil and then goin on the interstate. How about goin to a thicker oil?? I have 10w 30 in it now
SS/D 427 Ford Fairlane NHRA-IHRA (Ex- Van Cleve) 9.47@141mph
SS/D IHRA Record Holder
SS/E NHRA Record Holder 9.49 @ 139mph
1985 mustang Daily Driven N/A 331 10.78 at 123mph
Stephen Johnson is offline
post #18 of 22 Old 03-06-2007, 12:59 PM
i let it warm up check for leaks let it cool then go drive for a bit let it cool an drive it for a bit, varying the th rpm rang i'm in. i'm kinda easy on it till 500. i change the oil after the third heat cycle then again at 150mi then at 500mi then at 1500mi then at 2500mi then i switch to synthetic blended oil an let her rip.
96 GT- Complete 4v swap, 4.10's
93 GT- Traded
97 F150-PI swapped.
Fastfox400 is offline
post #19 of 22 Old 03-06-2007, 01:01 PM
mine is a flat tappet cam
post #20 of 22 Old 03-06-2007, 02:05 PM
Ray III's Avatar
Think of engine wear-in as the speed your car gains with respect to time when you accelerate from a standstill.
In the first two seconds, you might accelerate to 60 mph. Two seconds after that, you might only gain 20mph. And as you approach your top speed, your rate of acceleration continues to drop off, until you haven't quite topped out yet at 170 mph but it takes a full minute to get to 180 mph.
The majority of ring seating takes place in the first few minutes, where the most conflicting areas get worn off. Heat buildup is quite high because of this, which is why you NEVER load an engine in the first few minutes. After a while, you can apply some load, but too much will overheat rings and glaze the walls. After a couple hours runtime it's pretty much a functional powerplant, but break-in still continues. You can call it done at 1,000 miles if you like, but in reality engine wear will continue for the life of the engine.
this post property of RAYMOND
Ray III is offline
post #21 of 22 Old 03-06-2007, 09:52 PM
lx2gt's Avatar
i had a 88 f250 with a 460, put a rebuilt engine in it and drove from denver to vegas, 750 miles starting with climing the rockys, put 30,000 on it before i sold it, never had a problem with that engine.
lx2gt is offline
post #22 of 22 Old 03-06-2007, 10:04 PM
white99gt's Avatar
I agree.If Everything is right it doesnt require a "breakin".
On my 99, i installed the engine.Warmed it up.drove it around the block ,change the oil and went to the dyno for its tune.Motor had less than 10 miles on it ..Almost two years later its still going strong (actually stronger now than when it was first dynoed).
Current: 2013 GHIG BOSS 302 447rwhp~390rwtq
90LX 301rwhp~331rwtqSOLD
99 2V 2.2KB GT: 608rwhp~542rwtq SOLD
2v t-trim combo:621rwhp~504rwtq
white99gt is offline
