#1 |
Who uses Mallory Hyfire products?
Hello,
Considering purchasing the digital Mallory Hyfire VI multiple spark unit or the digital Hyfire VIal instead of the MSD digital 6 or the analog MSD 6al with the TFI mallory coil... The main reason I am adding either is to go with a novi 1000 blower as a spark based rev-limiter as opposed to the factory fuel limiter. I know that Anderson Ford Motorsport installed the multiple spark on the project car they have been doing in 5.0 mag lately. Anyone use these products or have any bad experiences with them? They seem to have a lot more bang for the buck compared to the MSD units. Thanks! Andrew
__________________
'90 LX Coupe 5spd Best: 12.3 @ 113 w/ 1.86 60' - SOLD - Highly Recommended Tuner: LaSotaRacing.com |
| Sponsored Links | |
Advertisement |
#2 |
Andrew, you're going to get mixed reviews on both those, but I'll give you my story-
I had 3 Highfire 6's, only one made it to a 3k oil change before going bad and being sent back. I switched to MSD, so far so good. I'm sure others will have the same story but with the msd failing. Keep in mind too, that the rev limiter in trhat Mallor VI isn't a soft touch. I don't know if it matters but it sure doesn't sound very good if you hit that rev limiter. lol good luck! Oh, and i had constant idle isuues when the Mallory WAS working as well.
__________________
1995 gt, 5 spd,306,gt40 y303 heads,tfs stage 1 cam w1.7rr's, tfs street heat intake, 75mm tb, 80mm pro m, 30lb injectors,longtube headers w/ or hpipe and flows, upr lca's & uca's, fms c springs,3.73s chrome bullitts w10.5 rear & 275bfg dr's.powerdynew/10lb pulley & sct tune by prospeed.410rwhp402tq |
#4 |
I have used both the Mallory and MSD. The Mallory worked great then just one day died. The MSD units seem to last longer. Look at all of your Nascars and who they use, it seems they all use MSD boxes.
__________________
331 stroker, Edelbrock Vic Jr heads, Holly sytemax intake, Ed Curtis Cam, Tremec 3550 trans |
#5 |
My Mallory died after a few months, luckily i used their TFI harness so all I had to do was swap connectors to get it running again. Has anyone ever sent one back to get repaired? What usually goes wrong in these ignitions when they die?
Brian
__________________
95 GT - H/C/I B&G Turbo, C4......will never be finished 01 Ford Jocus ZX3 - 217,XXX miles....32mpg 97 F350 CC 4x4 460- .............9-12mpg......empty |
#7 |
I've been running the HyFire VIA for three or four years now without problem. As mentioned above, you'll get mixed reviews. The MSD unit I had before that only lasted a few months. I made up a shorting plug using a mating connector in case this box goes bad. I just unplug the box, plug in the mating connector, and drive home. The Pertronix module in my distributor allows me to do that.
__________________
70 Maverick Grabber, 5.0 (Performer RPM 2.02/1.6 heads, RPM intake, Comp XE266HR roller cam, Holley 650 DP, long headers), T5Z w/Steeda TriAx shifter, 9" "N" case Trac Loc w/3.89:1, 31 spline axles. |
#8 |
waht about the Crane Fireball Hi Dig 6??
I have had 2 MSD fail on me. one 6AL and one digital 6 plus.
__________________
88 Coupe- R331ci, SB billet crank, titanium rods, 11.5:1, Vic Jr 220cc heads, S-trim 18lbs.,680rwhp. 06 GTO- Pedders Track ll, chrome Maggie TVS 2300- 540/550 @rw on 8lbs. 89 Coupe-MM road race 347, 11:1, AFR 205, Vic EFI, 400/385 @rw, NA 93 Black Mustang Cobra-R356ci, Victor 300cc heads, Sup Vic |
#9 | |
Scott
__________________
88 Supercharged LX Coupe ![]() 2005 Tahoe |
#10 |
i have used many of both brands and had failures with both,I prefer the mallory digital readout unit simply because of the extra boxes you don't have to buy from msd and no chips to change. Lamar
#11 |
I use the mallory digital 6 (pn 685) I choose it over the msd because it has so many features built in, 2 stage limiter, window switch, rpm switch, start retard, boost retard... etc.etc
__________________
My Rides 00 Ford F250 CC SB - 7.3L 89 Ford Mustang Coupe - 5.0L 00 Chev Corvette FRC - 5.7L |
#12 | |
Also like mentioned it has A LOT more features; LED display, digital rev limiter (no dials), built-in adj boost retard, etc)...all for almost $100 cheaper than the MSD dig box. Ignitions aren't completely predictable so it can be hit & miss. |
#13 |
I have used many
Msd boxes with many failures, I have switched to the Mallory 6 series boxes with no problems in with them and I have had one in service now for about 3 years. Best change I feel that I have made yet. No added boxes or clutter, no chips, and just as easy to install. I really like the all in one switches on the Mallory boxes.
#14 |
Just by listening to the problems that are had with MSD and Mallory, I would recommend a Crane HI6. I've been running mine for 2 years with no problems whatsoever, except better performance, less plug fouling, and a stronger idle (carbed car). I honestly haven't read of any major issues with the Crane unit.
__________________
'93 LX Hatch - 331 '79 Fairmont Futura Sport Coupe - Novi 1k '95 Ranger - 5.0 EFI '67 Comet Caliente Hardtop - in progress |
#16 |
I run the Mallory 685. it's got a ton of fetures for the price and is very user friendly. I did have one die, but Mallory was great and fixed it free of charge, it was about 6mos. old at the time. Personally, I think they all use pretty much the same circuitry and hard parts, so reliability should be about the same. MSD has always had the nickname "Might Suddenly Die" around my ciricle of car bud's, so go with what's right for you.
__________________
1990 Notch 302, TFS Top End Kit, PA C4, 3800 Edge Converter, 150hp NX, UPR Pro Series Rear, 4.10's Moser axles 6.84 at 98.72 1/8 Mile Best, trying to get better weekly |
#17 |
I had a Mallory Hyfire on the car when I bought it... Didn't like it much at all... It died after less than a year.. Switched to a MSD 6AL - love it!
__________________
1986 Ford Mustang LX 302 Yeah, it's stock 1999 SVT Lightning Yeah, it's also stock
#18 |
It can make a big difference if you mount the box away from heat and moisture.
__________________
#20 |
I also run the Mallory hyfire VI 685. I bought it because it has the digital display and it has like 9 different modes you can select from. im also running the map sensor with the built in boost retard for the blower. I mounted it inside the car so I can toggle and adjust the boost retard when im driving. I also like it because when you adjust the different values its a digital number rather than the rotary type knob like the old MSD boost retard box I had. I def recommend it.
__________________
90 Coupe, Ponydown Single Turbo Kit Holley systemax heads and intake, Crower 15511 cam G-force t-5, 3.55 gears, 5 lug conversion, chrome '03 cobra wheels... 11.52@123mph (old set-up) |
#21 |
So how did you guys run the wires, on any ignition box, from the coil in the engine compartment all the way to under the seat or on the pass side transmission tunnel.
Thanks! Andrew
__________________
#22 |
Drilled a hole in the passenger-side firewall and used a rubber grommet.
__________________
#26 |
Take a look at the Crane HI6. Not too many people seem to have complaints about them failing. That's what I went with. Have had no problems.
__________________
1994 Lazer Red GT, S-trim 1986 black GT T-top - SOLD |
| Sponsored Links | |
Advertisement | |
| Bookmarks |
Previous Thread
Next Thread
| Thread Tools | |
| Display Modes | |
Linear Mode
