runs rough when cold - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 4 Old 02-24-2007, 05:51 PM Thread Starter
93mustank's Avatar
Trader Feedback: (133)
I just purchased an 88 lx 5.0 5sp. I noticed that when its real cold(like just after startup) and I roll into the throttle it really hesitates and pops. But after 2 minutes or so it goes away completely. This is my fourth mustang (2nd SD) and I have never experienced this, any ideas.
www.facebook.com/FoxBodyPerformance
93mustank is offline
post #2 of 4 Old 02-25-2007, 03:36 PM Thread Starter
93mustank's Avatar
t
post #3 of 4 Old 02-25-2007, 11:35 PM
THELAW1's Avatar
It"s in warm up mode , the computer is giving it more gas for fast idle to warm up...when you try to give it more gas to move you are giving it more gas then the plugs can burn...just let it warm up till operating temp
89 Reggatta blue,Trickflow Intake,
1in spacer.65mmTB,GT-40 aluminum heads(X303),3000 Dynamic Converter, Motorcraft plugs 32c's ,E-cam,24lbs Injectors,Pro-M 76mm Mass air , AOD,shift-kit, modified valve body, 410 gear, Eaton
THELAW1 is offline
post #4 of 4 Old 02-26-2007, 01:52 PM
mine does the same thing till it gets a little warm.
87 LX 5.0 hatch Edelbrock 2.02/1.60 performer RPM heads and Intake, 1.72 rr's, f-303 cam, ARP head bolts, king cobra clutch, Hooker 1 5/8 w/ 2.5" exhaust, hurst shifter, BBK FPR, 190 LPH fuel pump, 75 mm MAF and throttle body, 76mm C&L pipe, 24 lb injectors, 3.73 gears, much more.
histosaid is offline
