Car's Apart ---- Coil Pickup ---- take apart distributor to change??? - Ford Mustang Forums : Corral.net Mustang Forum
Old 04-21-2002, 02:21 PM   #1
NewtStang's Avatar
The car died on me yesterday, after searching the archives for some ideas, I decided to replace MAF sensor and TFI module. I couldn't reach the screws for the TFI without pulling the distributor. While the distributor is out, I'm replacing the coil pickup. But I'll be darned if I can figure out how.
I removed the two screws holding the plate that guides the rotor, but there are no fasters holding the plate beneath that to the rod that goes through the distributor. The gear and stop at the bottom of the distributor look like they have to come off to slide the entire assembly out of the casing to swap the coil pickup.
But the gear and stop look like they're being held in by pins (sort of like coiled up metal?) that can't come out?
Ideas?
Thanks, Kyle
NewtStang is offline
Old 04-21-2002, 02:33 PM   #2
Member
SPORT89LX's Avatar
You need to knock the roll pin out with a pin punch and hammer to get the gear off.
Found a pic for ya
__________________
1989 Mustang LX 5.0l
SPORT89LX is offline
Old 04-21-2002, 02:48 PM   #3
NewtStang's Avatar
Gulp! Boy that sure looks like a moron like me could break somethin. I'll give it a try. Do the pins go back in or do they get ruined during the process?
__________________
-- Kyle
'92 LX Convertible (now a Lemons race car)
'90 LX Coupe (HPDE track car)
'94 Cobra (stock)
Old 04-21-2002, 05:32 PM   #4
Member
SPORT89LX's Avatar
They can be re-used. Just tap them back in.
__________________
You may not post new threads
You may not post replies
© 2010-2011 Corral.net
