Why do C&L mass air meters not like CAI??? - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 17 Old 04-15-2002, 08:09 PM Thread Starter
Question Why do C&L mass air meters not like CAI???
I have an 88GT and I am going to convert it to mass air in a few weeks and I bought a conversion kit with a 73mm C&L mass air meter. I have heard that some C&L meters don't like CAI and I don't want to run the stock unit or one that stays in the engine compartment, i would like to run a fenderwell unit either a desencharger or a power pipe from Anderson ford motorsport.
Is it possible to run these type units with C&L meters?
The codes on my C&L are:
F1ZF-12B579-AA
AFH55-03B
Then in a little boxed area is: 0C23
Do these codes mean anything?
Thanks for the info
88 Conv. GT
5 on the floor is offline
post #2 of 17 Old 04-15-2002, 08:17 PM
Hozer 88gtconv's Avatar
no probs..
see sig...
I am upgrading to the 76mm C+L with the power pipe though.
88 GT Convertible
306 w/SQ-Trim @ 8 lbs
434 rwhp daily driver
440 rwtq....
Hozer 88gtconv is offline
post #3 of 17 Old 04-15-2002, 08:25 PM
avbcon12's Avatar
Trader Feedback: (26)
the issue is due to the sample tube design on the C&L meters. when incomming air makes a 90 deg. bend right before the meter (like a CAI) the meter won read all the air that moves through the meter because a lot of the air is hugging the wall.
you can correct this problem by actually turning the meter until you get a more stable idle.
mine works great. although i dont have a CAI. just the stock box with K&N.
take care,
adam
90 GT black, V2 SI-Trim, Blow-Thru A/A Intercooler
stage 3 "Y" heads/ Bennett Racing intake, TFS#1, long tubes, 3"Pro-Dumps/H-pipe, TKO500, 3.55's, Home made TA and PHB, cobra brakes, 22 gallon Fuel Safe Cell, PMS tuned etc.. built for twisties
avbcon12 is offline
post #4 of 17 Old 04-15-2002, 10:09 PM Thread Starter
do the codes on the meter mean anything on what type of induction you can run?
post #5 of 17 Old 04-15-2002, 10:09 PM
avbcon12's Avatar
no
avbcon12 is offline
post #6 of 17 Old 04-15-2002, 10:25 PM
Corral Member
ALLL METERES, C&L, Stock, Pro-M etc.... are affected one way or another by CAI.
I was at a dyno session where the guy LOST 30rwhp with the additon of a CAI to a stock meter. He they tried a Pro-M, and only 8 hp came back He then took off the CAI and got all hsi power back. The compnay that made it has since supplied re-calibrated MAF sensors for their CAI kits.
Mass air sensors are calibrated to work with a certain quality of airflow. If you change this, you change the type of flow, and the meters readings WILL get out of whack.
Good luck,
Toma
Toma
Incon TT 5.0 Stock Short, 9.79 and best of 142.5mph. Pump Gas A9L 383w 9.26 @ 151
Toma is offline
post #7 of 17 Old 04-17-2002, 01:38 AM
SVO LOU's Avatar
Will a C&L 76mm MAF meter fit with the BBK or Mac cold-air kit without cutting the tubes or buying new connector hoses?
Lou.
4 wheels move the body, 2 wheels move the soul...
SVO LOU is offline
post #8 of 17 Old 04-17-2002, 08:56 AM
avbcon12's Avatar
it should
adam
avbcon12 is offline
post #9 of 17 Old 04-17-2002, 09:21 AM
likeike's Avatar
When you say cai do you mean the cone type filter that K/N makes???? If so this could be my idle probs<<<<<
2003 Mach-1 Azure Blue,
likeike is offline
post #10 of 17 Old 04-17-2002, 12:00 PM
Glenn's Avatar
My 76mm C&L works perfectly with my Moroso CAI, no problems at all.
Glenn is offline
post #11 of 17 Old 04-17-2002, 12:51 PM
My MAC CAI and 73mm C&L (19# calibration) have no problems...I have only slightly clocked the MAF towards the motor (if that makes sense), and have no idle problems. Of course, I also have a stock cam, and make 17" of vacuum at idle....
However, I will be doing track testing to see if the "CAI" is worth a damn thing at the track, because I don't believe it will be! It's just shiny, and was on the car when I bought it - I would never have actually spent the cash on it.
HTH
-Jacob
85 RX7 302/AOD
66 F100
02 WRX
cobracloud is offline
post #12 of 17 Old 04-17-2002, 02:40 PM
5oh
5oh's Avatar
Lou.
You maybe able to strech out the connectors enough, but I doubt it.
2 Cars and a truck
5oh is offline
post #13 of 17 Old 04-19-2002, 03:52 PM
mass air
i just got done inatalling a new 76mm C&L mass air on my car with cold air, and it runs perfect, i can tell a nice increase in power as the RPMs get over 3500
noney16 is offline
post #14 of 17 Old 04-20-2002, 01:38 AM
SVO LOU's Avatar
Re: mass air
Which cold-air kit?
Lou.
SVO LOU is offline
post #15 of 17 Old 04-20-2002, 01:42 AM
Re: Re: mass air
Which cold-air kit?
Lou.
i have the fenderwell mount bbk cold air
noney16 is offline
post #16 of 17 Old 04-20-2002, 02:03 AM
rtz
rtz's Avatar
They are talking about Cold Air Induction kits like these:
http://www.jdsperformance.com/index....id=94&fcmd=cat
Your probably getting fan wash. You should get a shield or mount that filter in the fender.
rtz is offline
post #17 of 17 Old 04-20-2002, 02:10 AM
No Control's Avatar
Even though I have a "mod motor" I do have the MAC CAI and the C&L MAF. The unit was previously installed on my friend's 99. He said he noticed a difference, and backed it up by .2sec on the 1/8th (only track near P.cola). The unit now resides in my car, and to tell you the truth, I'm not too happy with it. I'll be at Carlsbad this weekend, to test the combo out, but I doubt it did anything other than hurt the performance. I'll try turning the meter like abvcon12 said. I hope that works. I really don't want this thing in here, but my stock unit is in Fla, so I have no choice until I go back there next month.
Oh, BTW, for those wondering, the MAC inlet tube, the flange that holds the stock MAF has to be cut off. You can then use 4" sewer pipe (cheap and at home depot) rubber to mount the two. Once again, I'll try turning the unit and get back to you all later.
1998-Normal Stuff
*NEW BABY*
1992-Tri-Axe so far, more to come.
--If you're under control, you're not going fast enough. (Parnelli Jones 1970 Trans Am Champion)
No Control is offline
