TFI coil test using voltmeter - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 2 Old 03-21-2006, 02:10 PM Thread Starter
Coupester's Avatar
Trader Feedback: (41)
I have heard there is a resistance test using an ohm meter that I can do to a TFI coil to verify the coil is functioning properly. How is this test performed?
thanks,
Chris
82 Mercury Capri
N/A AFR 165, FTI cam
Coupester is offline
post #2 of 2 Old 03-21-2006, 06:48 PM
Joel5.0's Avatar
I think this is the procedure you're looking for. BTW and FWIW, some coils would pass the primary and secondary resistance tests, and still won't fire, or give other driveability problems. GL
ACRONYMS:
LUK=Let Us Know, GL=Good Luck, LMK=Let Me Know, JIC=Just In Case, BTSTDTRT=Been There Seen That Done That Repaired That, YCYDYP=Your Car Your Dough Your Prerogative and the classic... DILLIGAS=Do I Look Like I Give A S***
1986 Mustang GT w/T-Tops
NOW: 5.0L Stock shortblock, X303 Cam, SP Offy. Port-O-Sonic, 700 cfm DP Holley, 289 '66, 1.7 RR, Richmond Gear 4+1 Trans., Centerforce DF kit, 2.73 Gears
WIP: 3.90 Gears(Motive Performance), LS Overhaul (FRPP), Adj. LCA's (New Design Granatelli Aluminum), Adj. UCA's (Granatelli), Caster/Camber Plates (MM), Subframe Conn. (MM) T-Top weatherstriping and rear braces bodywork
Joel5.0 is offline
