What year Explorers have gt40 and gt40p heads? - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 4 Old 03-20-2006, 04:20 PM Thread Starter
TENGRAM's Avatar
Question What year Explorers have gt40 and gt40p heads?
What year Explorers have gt40 and gt40p heads? which Explorer intakes are compatible with fox 5.0s? how can i make sure i'm buying a well-running motor(from a salvage yard)?
89 GT T5, 3.73, mac 1 5/8 u/l,mac o/r h-pipe.3-chamber flow catback, mac CAI, C&L 73mm, cat pulleys, some weight removed
TENGRAM is offline
post #2 of 4 Old 03-20-2006, 05:11 PM
vinnietbird's Avatar
Trader Feedback: (132)
1996 has great GT40 heads,and they have the EGR provision.I just put a set on E-Bay about 5 minutes ago.They'll work great with the 5.0.The same year intake is also a great piece.I've got one on my 5.0 right now.As I stated,I like the '96 because it has the EGR.Good luck.
'88 Tbird..Z-Spec T-5,GT-40 by TMoss,BBK CAI,Ed Curtis cam,Trick Flow heads,1.6 Scorpions,MSD Dist.,3G,Mass Air with 24's,70mm t-body,BBK CAI,140 mph speedo,8.8 with 3.55's,BBK shorties,mini starter,O/R H-Pipe, Flowmasters,Deep n deeper Cobra R wheels,Taurus fan,CHE control arms
vinnietbird is offline
post #3 of 4 Old 03-20-2006, 10:18 PM
96-mid 97 = GT-40 with internal EGR
mid 97- up = GT-40p with external EGR
If you need to pass an emissions test, you need an intake with internal egr. If you have no emissions test, either intake will work
Do a search- there's tons of info. that same question gets asked at least once a week.
90 GT Convertible- Triple Black- Cobra intake and MAF, 24lb inj., "P" heads, Cobra 1.7 rr, Lunati cam, 73 mm fronts, 3:73, 190 lph, etc, etc, etc.
90topdown is offline
post #4 of 4 Old 03-20-2006, 11:03 PM Thread Starter
TENGRAM's Avatar
thanks
TENGRAM is offline
