Whats the best ford cam for a 351w. NO BS - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 21 Old 01-25-2006, 01:38 AM Thread Starter
project1988's Avatar
Talking Whats the best ford cam for a 351w. NO BS
Whats the best ford roller cam for a street 351w GT40 motor for about 5300 rpm? Tell me why and show me your combo/numbers. And no I do not want a custom cam.
project1988 is offline
post #2 of 21 Old 01-25-2006, 01:54 AM
Super Moderator
HELMUT RONER's Avatar
Trader Feedback: (23)
There is no best. You choose camshaft based on your entire combination and how you'll be driving the car in the long run.
Helmut
Originally Posted by MFE
HELMUT RONER is offline
post #3 of 21 Old 01-25-2006, 02:17 AM Thread Starter
OK thats true...but what cam pulls hard past 5000 rpm but also has good low end power? 10.1:1 compression, GT40 intake and heads and a 5speed?
post #4 of 21 Old 01-25-2006, 03:30 AM
Might try the X cam
66 Mustang
306 E7's/XE274H/Vic Jr
Stalled MVB TCI C4 3.89 gears
livewire is offline
post #5 of 21 Old 01-25-2006, 03:29 PM
94 Cobra R's Avatar
GT40 intake gives up the ghost at 5500, so why would you want a cam that can pull past 5k? And out of curiousity, why the limitation on one of the letter cams?
Jimmy -Go Gators!
'94 Cobra w/complete R Drivetrain - SOLD
2001 Ducati 996
94 Cobra R is offline
post #6 of 21 Old 01-25-2006, 05:38 PM
67mike's Avatar
TFS stage 1 rocks in mild 351w!!!!
1967 GT Coupe, 4 speed toploader, 393W, Custom Cam, Canfield Heads, Vic Jr Intake, Crane Ignition, Holley Ultra Avenger Carb, etc........
2003 GT Convertible, K&N cold air system, Magnaflow cat back, auto...MINT...Loving it!
67mike is offline
post #7 of 21 Old 01-25-2006, 05:50 PM
NUTTSGT's Avatar
I think that'd be too small for a 351W.
Eric
TOO MUCH IS...JUST ENOUGH
Originally Posted by Cellos88gt View Post
fine. I'm out. I don't need this place.
NUTTSGT is offline
post #8 of 21 Old 01-25-2006, 05:52 PM
Wolverine 1087 Have heard good comments on them. Though probably designed for a 302, would maybe have more mild manners in 351. x cam and tfs 1 also do deserve consideration.
fatjoe57 is offline
post #9 of 21 Old 01-26-2006, 12:02 AM
90NotchLX's Avatar
Here is my set up. It's a 69 351W bored .030 with 69 351 heads (untouched). It has Speed Pro Flat top piston. It has 9:5:1 compression. It also has a hydraulic flat tapped Crane cams duration @050 216in 228ex. valve lift .484in .512ex, 1.6 Scorpion roller rockers, MSD distributor. Moroso spark plug wires. Edelbrock RPM air gap intake (untouched) with Holley 750 Double Pumper. I have a C6 trans and 3.73 gear. I shift at 5100RPM and the best so far is 12.62@106
68 Falcon, FE 397ci glide, 9' with 4.56 gears. Broke the 487ci FE.
90 Mustang 69 351W, C6 2800 stall 3.73.
Driver (77 Mustang II) BBF 525ci A460 heads PG trans, Dana 60 rear, 4.10 gears, Full Chassis car
90NotchLX is offline
post #10 of 21 Old 01-26-2006, 01:22 AM
Hot Rod did a artical a few years ago with a honed 5.0 Performer upper to a truck lower, E303, R heads, 75mm tb, and hooker 1 3/4 lt. It made 458tq @ 4000 and 400hp @ 5000. They did it with 11:1 compress with 87 pump gas. They build a long rod 351, but you can make the same power without it, that I'm sure of. Swap the heads for some AFR 205 or Dart 210 and your gold.
14.977 @ 93.5MPH
1989 Black/Red GT......completely stock AOD
FMS headers, OR H-pipe, Dynomax Tubro catback, 3.73
96 16" GT Wheels, cheap 5-lug conversion, Strange 10-ways
Originally Posted by NUTTSGT
Lee makes some good pionts...I'll make another, Don't race it, if you're afraid to break it.
mastrdrver is offline
post #11 of 21 Old 01-26-2006, 10:50 AM
67mike's Avatar
I ran one with edelbrock rpm heads and intake, 351w, TFS 1 cam, 750 holley, yada yada........
FRICKEN RROCKET on the street!!!!!!!
67mike is offline
post #12 of 21 Old 01-26-2006, 10:58 AM
cam
why not use the same cam as ford put in their 425 hp 351 motorsport long block it seems to make some power and 425 HP is a good start?
Randy
71pinto is offline
post #13 of 21 Old 01-26-2006, 12:41 PM
So what you are really saying is I want to compromise what I am doing.
I find the "No BS" thing very funny followed up by no custom. That speaks volumes.
Do you have a hydraulic roller block? If not, are you going to use the Crane link bar lifter so you can at least use a std base circle camshaft? If not, do yourself a favor and use a hyd flat tappet camshaft with a std base circle.
Good Luck!
Jay Allen
CAMSHAFT INNOVATIONS
www.camshaftinnovations.com
Jay Allen is offline
post #14 of 21 Old 01-26-2006, 12:57 PM Thread Starter
Yes its a roller lightning block. Im sorry but not everyone wants to invest in a custom cam for $300 bucks. Later on when I upgrade the heads then Ill get the better cam. You know what I mean?
post #15 of 21 Old 01-26-2006, 02:15 PM
f-cam is a good all around cam for stock pvc issues.x-cam is too big for stock pistons.f-cam will build power to 6000$ and works great with the natural low end torque that the 351 brings.
nitrocoupe1985 is offline
post #16 of 21 Old 01-26-2006, 02:44 PM
I would stick with a cam that's specific for a 351 rather than a 5.0 piece. A 351 with it's longer stroke requires different valve timing than a 5.0 for max efficiency. Sometime compare the specs for Ebrock Performer RPM cams for a 302 and a 351. Same lift and duration but opening and closing points, lobe separation, intake centerline are all different to take advantage of the 351s longer stroke.
70 Maverick Grabber, 5.0 (Performer RPM 2.02/1.6 heads, RPM intake, Comp XE266HR roller cam, FiTech EFI, EDIS/MegaJolt ignition, long headers), T5Z w/Steeda TriAx shifter, 9" "N" case Trac Loc w/3.89:1, 31 spline axles.
bmcdaniel is offline
post #17 of 21 Old 01-26-2006, 06:37 PM
PipeMaster's Avatar
$300 is the same as some of the better cams though. So it's not that much. If you don't want an alphabet cam there are not many other choices in hydraulic roller cams except for the Trick Flow cams. So if $300 is too much, the no BS answer if probably the F or X cams, or the TF Stage 2.
I'm not flaming you either, cuz I may be in the same boat. I was considering going carb and solid roller on my 351w (trailer car) but am now flirting with staying EFI and adding a blower later. That means much smaller cam for me if I want to smog and register the car. Which basically puts me in the same situation as you. Do you need to pass emissions?
'03 Mach 1
'98 GT, 410w/C4
PipeMaster is offline
post #18 of 21 Old 01-26-2006, 07:41 PM
see my sig for combo its gettin yanked shortly in favor of a 408 hehe but runs great on the street and isnt all that bad on gas either oh and it loves nitrous too
86 coupe, 408,glide 101mm
810rwhp pumpgas tune...........
90lx351 is offline
post #19 of 21 Old 01-26-2006, 09:40 PM
94 Cobra R's Avatar
I got my Crower 15512 on Ebay with less than 100 miles on it. I paid $125 for it. Combine that with 1.7 rockers and I've got a nice, moderate cam for my 351. BUT, if I had to do it over, custom cam all the way.
Jimmy -Go Gators!
2001 Ducati 996
post #20 of 21 Old 01-27-2006, 01:33 PM
Mighty Mouse's Avatar
Trader Feedback: (51)
If you would consider a flat tappet cam (as a lot of roller block 351w's came with including the 95 Cobra R) - I used the A351 Ford Racing cam. It has nice street manners with a 5750 shift point. I am running it in a long rod 351w (yes I can run 87 octane - with 10.75:1 - and I get 25mpg). With that cam and desktop dyno ( knowing all aspects of the engine) - I put 417 to the wheels with ported Windsor JR heads, Performer RPM intake and matching carb.
Otherwise I have some experiece with a B cam and 1.72 roller rockers (516 lift) that did very well on a 351 with GT-40 heads (unported) and intake. He shifted around 5500 rpms - very quick and idled nice with a little lope. Good brakes pressure as well.
1986 GT Convertible Fordstrokers 445, High Ports and Super Victor Intake by Duane Busch, Holley HP EFI, and Team Z Suspension.
Mighty Mouse is offline
post #21 of 21 Old 01-27-2006, 01:56 PM
You could try a TFS stage 2 cam. Don't know if you'll have enough p/v clearence, but if it does it is better then the letter cams.
