weight savings of aluminum heads.... - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 18 Old 01-11-2006, 08:17 PM Thread Starter
how much lighter are a set of afr 185's compared to a set of e7 heads?
'91 GT: SOLD
'04 GT: Forged bottom end, MHS Stg 3 PI heads, Hi-Tech Custom Cams, MHS Vic Jr + elbow, custom turbo kit, Precision 7175, T-56 & 3.27's. 785rwhp/725rwtq @ 20 psi.
Macs Stang is offline
post #2 of 18 Old 01-11-2006, 08:33 PM
tached93gt's Avatar
Trader Feedback: (46)
roughly 20-25lbs per head
93GT electric red & titanium gray
306ci 7.44 @ 91mph 1/8mi gone but not forgotten
Friends don't let friends go to the track without sticky tires! 600 hp/10 sec 374" N/A build in progress.
tached93gt is offline
post #3 of 18 Old 01-11-2006, 08:52 PM Thread Starter
ok here is a better question. how much do e7's weigh, and how much do afr's weigh?
'91 GT: SOLD
post #4 of 18 Old 01-12-2006, 08:03 AM
Michael Yount's Avatar
The savings on a pair is 48-50 lbs.
Michael Yount is online now
post #5 of 18 Old 01-12-2006, 09:04 AM
NUTTSGT's Avatar
2 Aluminum heads weigh about the same as 1 cast iron head....notice I said "about" .
Eric
TOO MUCH IS...JUST ENOUGH
Originally Posted by Cellos88gt View Post
fine. I'm out. I don't need this place.
NUTTSGT is offline
post #6 of 18 Old 01-12-2006, 10:38 AM
Authorized corral.net Advertiser - Kocky Products
93Cobra#2771's Avatar
Trader Feedback: (25)
Location: Helping Paul/Bob/Michael/Jeff spend Brian's money
As Michael said...
For Sale: Reproduction Window Stickers, 87+ Mustangs, Cobras, Lightnings, and HD F150!
Richard White
H/C/I 93 Cobra
11' Hyundai Sonata 2.0T Limited
11' F150 SCrew 4x4 Ecoboost
96 Escort Wagon 1.9/5spd
96 Geo Metro 1.0 (small block)/5spd
93Cobra#2771 is offline
post #7 of 18 Old 01-12-2006, 10:39 AM
tached93gt's Avatar
I think we all have answered the question adequately but it appears that Macs Stang wants an exact answer(splitting hairs)
post #8 of 18 Old 01-12-2006, 11:45 AM Thread Starter
lol i just wanted to see if there was a difference as far as different brand heads go.
no disrespect for your answer i am just trying to loose as much weight off of the car as i can with this new engine swap.
my goal is to try and get the car down to 3000 lbs without me in it. so far it is around 3200.
'91 GT: SOLD
post #9 of 18 Old 01-12-2006, 12:03 PM
They are all within a pound or so of each other, I imagine. A tubular front crossmember, tubular control arms, and other odds and ends will help your weight goals...
Richard White
H/C/I 93 Cobra
post #10 of 18 Old 01-12-2006, 02:36 PM
maverick0716's Avatar
When I did my head swap in the summer I weighed both my old cast iron heads and my new aluminum heads. The irons weighed 50 lbs. each and the Edelbrock aluminums weighed 25 lbs. each.
1985 GT 5 spd
Best 1/8 ET: 8.5 @ 85 mph
Best 1/4 ET: 13.2 @ 107 mph
maverick0716 is offline
post #11 of 18 Old 01-12-2006, 11:53 PM
NUTTSGT's Avatar
I think I can take "about" out of my above post.
Eric
NUTTSGT is offline
post #12 of 18 Old 01-13-2006, 12:09 AM Thread Starter
50 lbs is 50 lbs though. anything helps at this point.
'91 GT: SOLD
post #13 of 18 Old 01-13-2006, 12:16 AM
you would be amazed on how much a bag of potatoe chips add to your stomach...
that 6 ounce bag of chips will end up being 6 pounds when they get stuck in your gut.....
Kato Engineering is offline
post #14 of 18 Old 01-13-2006, 12:30 AM Thread Starter
what else can i do to lighten up the car besides changing k members?
the car has to remain streetable as well. I have weld drag lites on all the time btw.
'91 GT: SOLD
post #15 of 18 Old 01-13-2006, 08:17 AM
It's all about how much you want to sacrifice on a driver. Racing seats, remove a/c, remove heater core, gut the interior - you name it. For the ultimate in weight savings, go to the lounge and look at the 96 Cobra/carbon fiber project that is a sticky thread at the top. It is amazing.
Richard White
H/C/I 93 Cobra
post #16 of 18 Old 01-13-2006, 11:13 AM Thread Starter
okay cool.
well so far i have an a/c delete from upr, i pulled the complete smog pump/lines, aluminum heads, front sway bar is gone, i am running welds all the way around.
that is what i have done so far.
how much weight do you think i have freed up so far?
'91 GT: SOLD
post #17 of 18 Old 01-13-2006, 11:23 AM
I dunno, but you could weigh each item with bathroom scales and see.
Factory seats are also heavy - some lightweight seats and rear seat delete would make a big difference...
Richard White
H/C/I 93 Cobra
post #18 of 18 Old 01-13-2006, 06:25 PM Thread Starter
just weighed my a/c compressor and it weighs in at exactly 20lbs.
I have to still pull the canister off of the firewall along with two more lines. so maybe 3-5lbs there.
also, I still have to pull the sway bar off the car. smog is out. I believe that was 13lbs when I weighed that last year.
cowl hood should save me some weight. probably another 20-25lbs I would imagine.
'91 GT: SOLD
