5.0 HO swap into Jeep - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 4 Old 01-08-2006, 11:55 PM Thread Starter
Finished engine removal from Lincoln donor. Have everything I think I will need. I have searched forum after forum and read a lot of articles and have heard that a 5.0 HO speed density system can be installed and made to run with minimal 5 wire or so connection, though I cant find enough to explain to my poor brain which 5 wires, and to what they need be connected to.
92 5.0 HO from lincoln mark vii
AOD transmission
going to install into a 92 Jeep Wrangler.
Any advice would be appreciated.
Anthony
a4x4junky is offline
post #2 of 4 Old 01-09-2006, 12:21 AM
Papa Cosmos's Avatar
There is a site that is about 5.0 swap's into jeeps,if I can find it I will send you a p.m.
Papa Cosmos is offline
post #3 of 4 Old 01-09-2006, 12:30 AM Thread Starter
I would appreciate it. Have found a bunch of sites that show a lot of information.
I removed the donor engine and computer. Removed the computer wiring harness, the engine harness was on the engine still. The last harness in the vehicle goes from a large grommet on the passenger firewall and connects to the computer harness, the engine harness, lights, charging circuit, starting circuit, antilock circuit, air-bag suspension, and back through the firewall by the brake master cylinder.
This is no ordinary harness...is like super-harness
Anthony
post #4 of 4 Old 01-09-2006, 12:57 AM
Cobra5.0Jeep's Avatar
I don't understand your question but i did this swap into my Jeep and its pretty easy. My dad and i just cut out the wires we knew we wouldn't need, like a/c and junk. I have a box full of most of the harness.
http://www.zandm.com is a company that does these swaps only in Jeeps.
I've installed an electric fan, an MSD dist, MSD coil, e303 cam, upper/lower intake spacer, 3g Alt., MSD 6AL, Hooker headers, i had a custom Hpipe made and i am running flowmaster mufflers
1968 Mustang Fastback 532
1984 Jeep CJ7 302
1995 Mustang GT 302
2003 F350 Super Duty 444
Cobra5.0Jeep is offline
