What is your idle vacuum reading with E303 cam? - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 7 Old 11-06-2005, 07:48 AM Thread Starter
Anyone with a E303 cam please post your idle RPM and vac readings. thanks
Bullet306 is offline
post #2 of 7 Old 11-06-2005, 09:58 AM
Michael Yount's Avatar
You really need to know the rest of the set up too - not just the cam choice, as well as how it was installed.
Stock/healthy bottom end; Y303 heads; 1.7 rollers; Explorer intake; 65mm/75mm t-b and maf; stock HO headers and a 2.25" into single 3" system a la F-body. It was degreed in 'straight up' - .050" lift at 0 degrees TDC. I was never able to achieve more than 13" of vacuum and that was at about 1100 rpm. At 900 it would barely run - about 11" of vacuum. I made a TERRIBLE cam choice with my then limited exhaust system.
I've since altered the exhaust and put a custom cam in. MUCH happier am I. I sold the E used and the guy that bought it has since taken it out and sold it. I am convinced there is just one E cam out there that simply gets passed around from person to person -- as they each realize in turn there are much better choices. So I guess you have it now. Guess what the solution is gonna be?
Michael Yount is offline
post #3 of 7 Old 11-06-2005, 10:28 AM
bhleonard's Avatar
Trader Feedback: (54)
E303, Cobra intake, Longtubes w/ 2 1/2" exhaust, 65mm Throttle body. I idle at 750-800 rpm and hold 16+ psi vacuum at idle.
bhleonard is offline
post #4 of 7 Old 11-06-2005, 12:29 PM
My E wil 1.72's and P heads showed 12".
Eric
89 GT Blown 392 9.50@143.4. Run'in on Corn:cool
98 Dodge Viper GTS
paxtu22 is offline
post #5 of 7 Old 11-06-2005, 01:37 PM
The Hawk's Avatar
13 inches of vacuum
850 rpm idle
Cam installed straight up
Combo: 306ci, Edelbrock Performer intake w/BBK 70mm throttle body, AFR 165 heads, Scorpion 1.6 roller rockers, Paxton NOVI 2000, 80mm Pro-M MAF, BBK 1 5/8" Shorty headers, MAC 2 1/2" H-Pipe w/cats and a 2 1/2" Dual Stainless Catback
My Website:
The Hawk is offline
post #6 of 7 Old 11-06-2005, 02:04 PM
slovakiansniper's Avatar
I have an e-cam advanced 4 degrees with edelbrock heads and a gt-40 intake and a a-trim. It sits at 12 inches at 850rpm's.
11.81@121mph
2006 Fun Ford Weekend True Street Editors choice.
2007 Epping Fun Ford Weekend True Street
Class Champion
slovakiansniper is offline
post #7 of 7 Old 11-06-2005, 03:48 PM Thread Starter
Thanks everyone for the responses.
I am seeing a steady 10" at 950rpm idle with my E303. It was installed by the previous owner and have not taken the front of the engine apart, so I don't know how it was installed.
It idles slightly rougher than I think it should along with the low vacuum reading. I did a compression test and all cylinders were 165-170psi except for #3, which was in the 145-148psi range. So my thinking is that the valve adjustment on that cylinder might be slightly too tight, causing lower than normal compression and vacuum readings, along with the rougher idle.
Combo is a factory 5.0L short block, E303, Edelbrock heads, 1.6 rockers, 65mm TB, Performer 5.0L intake, 1 5/8" shorties into 2.5" H-pipe & catback, and a Paxton SN89.
