Victor 5.0 efi vs Spyder efi on 306 (Mass-floefi.com) - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 14 Old 06-08-2005, 07:23 PM Thread Starter
Trader Feedback: (40)
Which intake system would be best on a 306 NA only, 10.5 to 1 CR, with 195 Canfield heads( 58cc), 1087 Wolverine cam, 1 3/4LT, 3" X-pipe to 2 1/2" tailpipes, 5sp, 3.73, 3000lb coupe for 90% street and 10% track?
1. Victor 5.0 EFI with 75mm TB, 80mm Pro-M, 4" or 3.5" AFM power pipe and 8 36lb injectors.
or
2. Victor Jr EFI with 4bbl style TB(1000cfm), 85mm GM LS1 style Mass meter converted for Ford EECIV, with raim air style carb air cleaner and 8 36lb injectors. check out www.Mass-floefi.com.
Ultimately either package will be put on a 400RWHP NA 347 with port work and custom cam to suit the intake. But right now, which package could I drive for a year until the new 347 short block is ready?
Thanks,
Rob
Rob50lx is offline
post #2 of 14 Old 06-08-2005, 10:04 PM
tached93gt's Avatar
Trader Feedback: (46)
based on 90% street and 3.73 gears I'd say the Holley intake although you did not mention it here, of the 2 listed above I vote Victor.
93GT electric red & titanium gray
306ci 7.44 @ 91mph 1/8mi gone but not forgotten
Friends don't let friends go to the track without sticky tires! 600 hp/10 sec 374" N/A build in progress.
tached93gt is offline
post #3 of 14 Old 06-08-2005, 11:14 PM
flyin2jz's Avatar
I have the victor efi intake and its bad ass. The thing comes on like a turbo at 4k. you wont be upset witht he victor efi
93 gt 352 ci 302 based alum rdi block,bryant billitt crank, je pistons,Bullet racing ots hr cam, linkbar lifters,tfs r heads,super victor efi,42lb injectors, abaco 97dbx meter, 90 mm accufab tb, jesel shaft mount 1.7 rockers,kooks headers, g force t5, 4.56s, 10.52 at 130, 498rwhp/387ftlbs
flyin2jz is offline
post #4 of 14 Old 06-09-2005, 12:24 AM
Stang5lgt's Avatar
The Victor Jr. rocks when I hit 3k rpm it's like someone flipped a light switch. I have a Novi 2000 pushing air through it.
Stang5lgt is offline
post #5 of 14 Old 06-09-2005, 12:49 AM
jdj
i have run a similar combo..victor 5.0 intake (still using it on my renegade car) 306 11:1 comp victor jr. heads and a custom grind hyd cam set up to rev to 7500rpm..that motor put 375 to the ground n/a...
since then i've seen some better more reliable combos though..i've seen a 331 with afr 185's an f303 cam, and a rpm II intake put 380 to the ground at 6200 rpm.. look into the rpmII if you don't want to ring that motor out.. it's a really good intake!
9.6@ 140 on 5 cyl
ffw s\r 16
jdj is offline
post #6 of 14 Old 06-09-2005, 04:42 PM Thread Starter
I know there are better intakes for a 90% street motor; but, I am really set on a Victor 5.0 or Victor Jr. Besides, I can get a good deal on either one. I have also seen that when either Victor intake is on a 347 they can be very streetable with a custom cam. I am currently running a 650DP and a ported Performer RPM and I like that I can spin it to 7000 rpms.
flyin2jz I have been following the other thread about the victor efi and I agree it is an awsome manifold.
Stang5lgt and jdj
I even had a victor jr intake once with my current combo and really liked it on my car; but I bought it used and I think it was milled or something cause I had serious isssues with getting the ports to line up and had coolant leaks. I would have no problem going back to a victor jr.
I know the long runner Victor 5.0 efi will have the possiblilty of offering more torque than the short runner victor jr. efi (Spyder). What I would like to know is if the 4bbl style TB on a victor jr will change the air flow characteristics.
I wonder if my combo with a victor jr. efi maniold and the canfield heads would be a good canidate for one of Jay Allen cams?
Rob
Rob50lx is offline
post #7 of 14 Old 06-09-2005, 06:24 PM
Stang5lgt's Avatar
My car has no cam stock bottom end. With Victor Jr 5.0 heads and Victor Jr. 5.0 intake with 75mm TB. And of course the Novi. If you got my gallery you can see my motor. You will not gain any bottom end. But it will scream at the top. I know. My car is lowered 2 inchs. And I have tube upper and lower control arms. I took it to the track with a set of BFG drag radials and some good ol low profile tires. I spun tire all the way down the track. My wife said it look like the tires were breaking loose everytime I shifted all the way through 4th. That was last time I was at the track poped a head gasket. My time was 13.1 at 115mph. With street tires. My 60 foot time was 2.02. Good set of slicks would get me into the 12s easy. Anyway Victor Jr. is good for 500hp out of the box on a NA motor. Plus it looks really cool.
post #8 of 14 Old 06-09-2005, 08:53 PM Thread Starter
I like the fact that with either Victor intake it is easy to remove the valve covers. I really like the looks of a traditional carb intake and the motor should spin better with the short runner length, but at the cost of some torque.
Here is some pros and cons I see for both intakes compared only to each other:
Victor 5.0 efi
pros
Long Runner-- More Torque potential
Cam timing not as critical
Clears stock hood
Easy access to valve covers
Easier to swap to a more streetable intake
Easier to add blower
Cons
Heavier than Carb style intake
More restrictive intake tract
Victor Jr. efi (Carb style)
pros
Cool Carb look
Lighter weight
Less restrictive intake path
Motor will more likely spin higher
Easy to add nitrous carb plate
cons
Harder to change to more streetable intake
harder to add supercharger
Throttle linkage problems
May or may not fit stock hood (depending on air cleaner)
Short runner-- less torque potential
Short runner design makes cam timing more critical.
*edited to correct mistakes pointed out by Bullhead
Rob50lx is offline
post #9 of 14 Old 06-09-2005, 08:56 PM
Bullhead's Avatar
Originally Posted by Rob50lx
Victor 5.0 efi
pros
Clears stock hood
Cons
If something is easier shouldn't it be a pro and not a con?
Bullhead is offline
post #10 of 14 Old 06-09-2005, 08:59 PM
buy the "elbow" from CHP, then your throttle body will be the stock location...
kloven is offline
post #11 of 14 Old 06-09-2005, 09:22 PM Thread Starter
Bullhead
Thanks, I went back and corrected my post. It's 3am here, my brain is failing me.
kloven
I have thought of the "elbow", but I don't like the looks of it. But that brings up more questions.
1. When using a "Spyder" intake what are the performance differances between a 1000cfm 4 blade carb style throttle body and a traditional 75mm single blade throttle body?
2. Is the GM LS1 style 85mm MAF better than a 80mm Pro-M or a 90mm LMAF?
Griggs GR-40 coil over front suspension with Koni SA Yellows w/350# springs in front with Brembo 13" front brakes, EVM Tri-Link, Leda Coilovers w/275# springs in rear. 8.8/9" hybrid rear axles with cobra calipers and rotors. 17x9 real Cobra R with 245/40ZR17 Sumitos.
Rob50lx is offline
post #12 of 14 Old 06-10-2005, 12:25 AM
thinkid17's Avatar
use the longer runner victor efi for sure, other choices better suited for power production and not looks, systemaxII, RPMII, TFS-R
currently in between cars. previous rides: 75 F-100 stroked 390, all alum. top end and TKO.
87 notch 331 cage Ed Curtis custom stick, nitrous, X2C TKO, Ron Anderson heads blah blah.
96 mystic cobra all the boltons, and i do mean all.
thinkid17 is offline
post #13 of 14 Old 06-10-2005, 02:54 PM
Bullhead's Avatar
Bullhead
NP man
Bullhead is offline
post #14 of 14 Old 06-10-2005, 06:08 PM
5.0_CTDAK_fam's Avatar
Have you run your car at Bitburg?
QUOTE=Rob50lx]Bullhead
kloven
2. Is the GM LS1 style 85mm MAF better than a 80mm Pro-M or a 90mm LMAF?[/QUOTE]
5.0_CTDAK_fam is offline
