MAF and/or Throttle Body size / sizing chart ? - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 5 Old 06-01-2005, 10:47 AM Thread Starter
Matt Kennedy's Avatar
Question MAF and/or Throttle Body size / sizing chart ?
May be a bit naive on my part (over simplifying?) but is there a MAF sensor and/or TB sizing chart out there. From a novice perspective it sure seems like it would be a decision based on having a MAF and/or TB sized to match/support the flow of the intake and heads. If so it seems like there must be some sort of maf size to supporting flow type chart. Did a search and couldn't find anything. Found one link that referenced a pro flow web site but link/site returned "no site found".
Replacing stock intake to better match my heads very soon. Would like to better understand whether the need for a MAF and/or TB is in my future and/or whether I'd benefit from upgrading same.
If it is not as easy as referencing a chart how does one determine scientifically (much prefered over pure anecdotal recommedations) what the proper maf size is for a particular setup?
Thanks!
-Matt
(2200 lbs) '89 5.0 driveline: 306 EFI, Performer Heads, Scorpion RR, FTI cam, GT40 Intake (Tmoss ported lower), 65mm TB/EGR, PMAS 80mm, FRPP 30lb, 255lph, shortys, stock BE, T5/Pro5.0, '88 t-bird TC 8.8 w/3.73s/disc.
Matt Kennedy is offline
post #2 of 5 Old 06-01-2005, 06:03 PM
351Freak's Avatar
a rough guideline only...flywheel HP
stock can make about 350
65 can make about 450
75 can make 550
this ASSumes naturally aspirated and are ball park #'s
351Freak is offline
post #3 of 5 Old 09-03-2006, 06:40 AM
KKKKatmandu's Avatar
Question
75 can make 550
Is this still considered accurate ?
What size does a 91 GT have as stock ?
KKKKatmandu is offline
post #4 of 5 Old 09-16-2006, 05:25 AM
Question
Can someone please expand on how to pick the correct size Throttle Body and MAF for one's application ??
post #5 of 5 Old 09-16-2006, 12:38 PM
stangPlus2Birds's Avatar
See Holden's book in my sig.
A MAF 75mm or bigger won't be a restriction. A 70mm TB or bigger won't be a restriction. A 65mm TB is not a restriction until ~600 HP.
As you go to a bigger TB, you loose low-end throttle response. It's minor and not important for most people.
Joe - 86 Mustang GT with ABS!
M-2300K brakes, Mach1 Springs, D178 rims, and 245/45/17 RE730 tires. Car Pictures: http://www.veryuseful.com/mustang/tech/misc/Mustang1986_with_Mach1_springs/
stangPlus2Birds is offline
