smoke inside the car? - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 8 Old 04-18-2005, 12:13 AM Thread Starter
Question smoke inside the car?
i have an 89 gt mustang. when i get on the car . . . smoke fills the car outside and in. however when i drive it regular it seems to run fine. also when i am idling the oil gauge seems to level low. is there a leak or should i just add oil? any advice would be great.
rguba3pt3 is offline
post #2 of 8 Old 04-18-2005, 12:25 AM
pepe's Avatar
Posssible a major leak somewhere down there on the H pipe. You can really know where its comming from until you look down and trace the leak, could come from many different areas under engine components.
pepe is offline
post #3 of 8 Old 04-18-2005, 01:26 PM
Check to see if you still have your dip stick tube. Happened to me once , car was fine until 5 grand and then I thought it was on fire
JOHN 86GT is offline
post #4 of 8 Old 04-18-2005, 01:30 PM
Snowboarda42's Avatar
yeah look at your exhaust to see if theres any oil burns on there(black markings from oil burning off) and find where its coming from. then see if your exhaust is leaking.
Snowboarda42 is offline
post #5 of 8 Old 04-18-2005, 03:50 PM
gt50stang89's Avatar
had the same exact problem and it was oil coming out the dipstick burning on the header cause it wouldnt stay on tight, little electric tape fixed the problem.
1989 Mustang GT
CHP 347
2012 F-150 FX4
gt50stang89 is offline
post #6 of 8 Old 04-18-2005, 04:36 PM
Authorized corral.net Advertiser - Kocky Products
93Cobra#2771's Avatar
Trader Feedback: (25)
Location: Helping Paul/Bob/Michael/Jeff spend Brian's money
And the smoke is getting in some how or another - my guess is through the tranny tunnel - the rubber boots get torn/cut during ANY tranny work...
For Sale: Reproduction Window Stickers, 87+ Mustangs, Cobras, Lightnings, and HD F150!
Richard White
H/C/I 93 Cobra
11' Hyundai Sonata 2.0T Limited
11' F150 SCrew 4x4 Ecoboost
96 Escort Wagon 1.9/5spd
96 Geo Metro 1.0 (small block)/5spd
93Cobra#2771 is offline
post #7 of 8 Old 04-18-2005, 05:48 PM
Nitrous SSC's Avatar
You could have a rear main leak. And when you romp on it all the oil goes to the back and then the higher exhaust temps cause it to burn off..
Also the rear of your valve covers or lower intake could be leaking too.
Bonneville 130 club member. (139.993) 11.48@123 in the 1/4.
Nitrous SSC is offline
post #8 of 8 Old 04-18-2005, 05:55 PM
I have smoke come thru my tranny/shifter area and it does it when I get on it hard...and I got to looking at I have a leak on the back of my lower intake. It gets on my tranny...and gives off a "watery eye" smell...
I have also had it (it was considerably worse - it would do it under regular driving) a BAD rear main seal leak and it would smoke pretty badly constantly (needless to say I didn't drive it much), it got on the tranny/h-pipe and burned...
Since the lower intake leak my oil pressure guage shows a bit of a drop as well...surely it's related Would that do it? An oil leak at the back of the intake?
Laser Red 1998 Mustang GT - Daily Driver, 5spd, Leather, Mach 460.
Reef Blue '93 LX 5.0 5spd
New 306, AFR 165's, FTI cam, Tmoss Performer Intake, Scorpion 1.6 RR's, 30lb injectors, Pro-M 75mm MAF, FRPP 65mm TB, Kirban AFPR, BBK Longtubes w/ matching H, Flows, 3:73's, Steeda Tri-ax, Mac Cai, Black Magic Fan, Griffin Radiator, 3g Upgrade and more...
Sold
Performance Red 2000 Mustang GT - Mac Catback w/ 3.5in tips, Prochamber, Pro 5.0 shifter, 01 Hood Scoop, White Face Guages and 17x9 Chrome Cobra R's
5spd GT is offline
