Serpentine Belt Routing Diagram for 5.0 (see inside) - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 16 Old 03-11-2005, 01:49 PM Thread Starter
Question Serpentine Belt Routing Diagram for 5.0 (see inside)
I have an 89 5.0, it has no smog pump, no power steering and no a/c.
It has an alt, crank and water pump and tensioner naturally.
How can I route the serpentine belt? does anyone else have a set up like this?
Stang5Oh is offline
post #2 of 16 Old 03-11-2005, 04:59 PM
what is your email and i'll send you a pick of it
89roller is offline
post #3 of 16 Old 03-11-2005, 05:30 PM Thread Starter
email
Fattuesdaze81601@aol.com is my email
Thank You
Stang5Oh is offline
post #4 of 16 Old 03-11-2005, 05:56 PM
fleeta's Avatar
I was wondering the same thing.
At the track, how can I bypass the P/S and A/P WITHOUT A/C?
Midnight Blue '88 5sp notch.
3.55's, UD crank pulley, ET streets, and some timing.
13.68@100
with 210k and counting....
fleeta is offline
post #5 of 16 Old 03-11-2005, 06:24 PM
what is your email
89roller is offline
post #6 of 16 Old 03-11-2005, 10:26 PM
This is the set-up I'll be using this year... no smog, A/C or power steering...
http://www.replicaparts.com/standard...ump%20page.htm
1994 Ford Mustang GT - 331ci, Probe SRS flattops, Twisted Wedge Heads, Track Heat Intake, 75mm TB, AFM Powerpipe, 80mm Pro-M MAF, 30# injectors, F303 cam, 1.6RRs, BBK longtubes, MAC O/R H-pipe, Flowmaster catback, 50-150 NX kit, TwEECer R/T
NEohioSTANG is offline
post #7 of 16 Old 03-11-2005, 10:32 PM
indy2000's Avatar
That better be a standard rotation Water pump.
indy2000 is offline
post #8 of 16 Old 03-11-2005, 10:32 PM
how did you post your pick up
89roller is offline
post #9 of 16 Old 03-11-2005, 10:48 PM Thread Starter
89 Roller...the pic you sent me doesn't help me much. It shows it with the A/c compressor in place.
I don't have A/c.
I have the same setup as the picture, but the reverse rotation water pump. Is there any other way I can do this??
I just bought a new alum high flow water pump, and don't want to spend any extra money on the pump or adjuster bracket.
Stang5Oh is offline
post #10 of 16 Old 03-12-2005, 10:51 AM
Stang
I don't think your going to have any luck with this.
The pic above, shows a good idea. But like indy said. Its turning the wrong way if its a stock water pump.
I just looked over at March. They have something but you have to use an electric water pump. Thats a lot more $$$$.
Here's a link if you want to check it out, or if you haven't already.
http://www.marchperf.com/pg30.html#elecwp
FORCED87GT is offline
post #11 of 16 Old 03-12-2005, 11:09 AM Thread Starter
I might have to add a pulley in there somewhere (like an idler) maybe i'll buy the a/c eliminator pulley so i can route the belt in a similar fashion...
Any other ideas?
Stang5Oh is offline
post #12 of 16 Old 03-12-2005, 10:41 PM
indy2000's Avatar
Any other ideas?
that'll be your most cost effective way unless you still have the compressor and use it as an idler.
indy2000 is offline
post #13 of 16 Old 03-13-2005, 02:51 AM
Super Moderator
HELMUT RONER's Avatar
Trader Feedback: (23)
Standard rotation water pump ASC WP641 or NAPA 55-4052
1993 Cobra water pump pulley
The bolts for the water pump pulley to be used without a belt-driven fan are 5/16 x 3/4 24-thread which I bought at Lowes.
Regular underdrive crankshaft pulley
3G alternator with stock pulley that came on it.
Dayco Poly Cog 5060450, $22.88 at Advance Auto Parts (you might end up using 5060445 / 6PK1130 if it needs to be ½ inch shorter).
Helmut
Originally Posted by MFE
Last edited by HELMUT RONER; 04-27-2005 at 12:56 PM. Reason: Corral photo host was down when I posted picture the first time
HELMUT RONER is offline
post #14 of 16 Old 03-13-2005, 09:12 PM
fleeta's Avatar
Originally Posted by 89roller
what is your email
ians@295.ca
Thanks.
13.68@100
fleeta is offline
post #15 of 16 Old 03-13-2005, 09:18 PM
fleeta's Avatar
This is what I had in mind, but I assume this is not adviseable if I still have the stock flow water pump. Am I right?
13.68@100
fleeta is offline
post #16 of 16 Old 03-13-2005, 09:41 PM
Super Moderator
Right. These pumps are just under $30 with a lifetime warranty, though (be sure you put your receipt in a safe place). If you get one and use the 1993 Cobra water pump pulley you will have to clearance the bolt holes in the pulley a bit so that you can screw the bolts into the pump. You'll need a Dremel.
Helmut
