Oil leak has stopped! Lucas oil and 1.5oz brake fluid - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 13 Old 01-01-2005, 08:01 AM Thread Starter
I finally cured my oil leak after using synthetic oil and causing several leaks. I changed the oil back to conventional oil and added 1 quart of Lucas oil stabilizer and 1.5oz of brake fluid. I ran the car for short while and dried off the oil leaks. Just checked this morning and I am absolutely amazed. The leaks have COMPLETELY stopped. Thanks for the help everyone!
***Caveat***
I do not work for Lucas oil and this was a gamble that may not work for others. However, it worked on my 7,000 original mile GT Convertible.
Cheers and Happy New Year
usa88gt is offline
post #2 of 13 Old 01-02-2005, 12:22 AM
88cat's Avatar
Where was it leaking oil from? I've never heard of adding brake fluid to the oil.
88cat is offline
post #3 of 13 Old 01-02-2005, 12:33 AM
Brake fluid????????
David737-300 is offline
post #4 of 13 Old 01-02-2005, 12:34 AM
marius's Avatar
ive heard of adding a SMALL amount of brake fluid to the transmission to help a slipping tranny. i was going to try it in my bronco but i think the tranny is done with. but i do recommend lucas products. i used to have a 1 quart every two week leak in my broncos tranny. i put some lucas tranny additive in and it pretty much stopped the leak. i think i added one quart every 2-3 months. much better than every two weeks imo.
86 gt many mods
07 R1 a few mods
02 Z71 tahoe no mods
marius is offline
post #5 of 13 Old 01-02-2005, 01:10 AM
S-Trimmed302's Avatar
Trader Feedback: (119)
I would never have the Guts to add Brake fluid to my Crankcase..Maybe if it was a 1981 Toyota carolla with 524K miles..Then I would use 5 quarts of Brake fluid instead of using Oil in the Motor..
My 92 Coupe- Under construction - Dart 347, TFS 205 11R heads,Custom Cam by Brian Friedentag "freezy74",TFS Box R Intake, 75mm Accufab TB, Hooker Supercomp 1 3/4" Full Lengths,Vortech Pass side YSI,8" Crank,2.85 blower pulley,Treadstone 1245-28 Intercooler,Snow Stage 2 Meth kit
S-Trimmed302 is offline
post #6 of 13 Old 01-02-2005, 01:25 AM
Lee8995's Avatar
Thats an old trick that used car lots used, The brake fluid swells all the rubber seals and or gaskets and stops the leaks. The bad news is its only temporary and when the seals start leaking it will resemble old faithful, The brake fluid first swells the seals then the seal material will start to break down and leak, You have just commited yourself to replacing all seals and gaskets soon.
The real reason that we can't have the Ten Commandments posted in a courthouse is this:
You cannot post 'Thou Shalt Not Steal,' 'Thou Shalt Not Commit Adultery,' and 'Thou Shall Not Lie' in a building full of lawyers, judges and politicians...It creates a hostile work environment.
Lee8995 is offline
post #7 of 13 Old 01-02-2005, 02:13 AM
marius's Avatar
the only reason i considered it on my bronco was because the tranny was on its way out. i just wanted as much life out of it as i could get, but i never did put brake fluid in it. for some reason i could never bring myself to do it.
86 gt many mods
07 R1 a few mods
marius is offline
post #8 of 13 Old 01-02-2005, 02:51 AM
Lee8995's Avatar
Well my advice is to not do it, If you need to rebuild your tranny or replace the seals and gaskets in your engine nothing you pour in with the oil is going to change that. It will work for a very very short while but then it will start to leak worse than you can imagine.
Lee8995 is offline
post #9 of 13 Old 01-02-2005, 03:19 AM
DarkMesa8's Avatar
The exact same thing happened to me when I went from dino to synthetic. Front and rear main seals were leaking like a waterfall.
I, like you, went back to dinosaur oil, and dropped a quart of Lucas in. I didn't even need the Lucas after the first 3000 miles and oil change, she just holds herself together now on her own.
Lucas is great stuff.
1991 Grey Mustang LX Hatch
1995 Jeep Grand Cherokee Limited V8 4x4
1994 Suzuki GSX750F Katana
DarkMesa8 is offline
post #10 of 13 Old 01-02-2005, 08:08 AM Thread Starter
Time will tell for me. I can't see 1 cap full and a half of brake fluid, causing any of the above. I will keep everyone apprised.
usa88gt is offline
post #11 of 13 Old 01-02-2005, 07:27 PM
Super Moderator
HELMUT RONER's Avatar
Trader Feedback: (23)
7,000 mile original convertible. 1988 assuming from your user name. By now those gaskets that leaked because you say synthetic oil caused them to are dry-rotted or rotting regardless of mileage. They're old. Replace said gaskets and be done with it. Valve cover gaskets just need to come out and use a whole tube of RTV for the valve covers alone. With only 7K on the clock why even bother switching to the synthetic?
Helmut
Originally Posted by MFE
HELMUT RONER is offline
post #12 of 13 Old 01-02-2005, 09:01 PM Thread Starter
Helmut,
I agree that they are old etc... due to the age and mileage. I just didn't want to touch the motor. Kinda anal I guess??? I am looking at an 88GT hatchback with very low miles 11,900 +/- and he says the heatercore is leaking? Is that possible with such low mileage?
usa88gt is offline
post #13 of 13 Old 01-02-2005, 09:40 PM
Ray III's Avatar
all mileage means is that the car has covered distance.
There is some wear that is mileage related: tires, suspension bushings, shocks, rock chips, powertrain wear.......
You can cut down on that sort of thing by not driving it much, but you can't stop time. Engine oil breaks down, cooling system can corrode and plug, tires can dry rot if exposed to sun, oil seals will rot as well.
this post property of RAYMOND
Ray III is offline
