best way to clean rusty flywheel - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 3 Old 03-11-2002, 01:38 PM Thread Starter
PUR PONY's Avatar
First off this is a stock 93 flywheel.
2 yrs ago when i replced my clutch i had this flywheel surface ground just a little to clean it up from its 80,000 use.
The motor and flywheel have now been sitting on an engine stand for the last yr and the flywheel is once again a little rusty- just surface rust.
can i get by with wet sanding this??? or should my friend surface grind it again??
thanks
-'89 Coupe - Incon Twin Turbo - Sheetmetal Elbow on a EFI Victor-Trick Flow Heads-Viper T56-RXT-Baer Brakes-iforged Wheels-Griggs,MM,KB-DFI-563RWHP/610RWTQ
PUR PONY is offline
post #2 of 3 Old 03-11-2002, 01:51 PM
corey90gt's Avatar
try some brake parts cleaner or some steel wool, or a 3m rubber bristle disc on a die grinder should take it right off and not damage the machined surface.
91 LX Hatch 4 Cylinder conversion Under Construction
90 LX Hatch SOLD
90 GT Hatch SOLD
corey90gt is offline
post #3 of 3 Old 03-11-2002, 03:16 PM
Yup, steel wool or block sand it with emery cloth, but that rust isn't going to hurt anything, so don't sweat it too much.
If the surface of the flywheel was glazed or crazed or warped, it might not grip the clutch and that would be a problem. But light rust won't make much difference to performance. That rust will be dusted off the first time you shift gears. It might make the clutch a little 'grabby', but that wouldn't last.
pcmenten is offline
