Where does thermostat gasket go exactly...on manifold?...on housing?...etc... - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 12 Old 07-24-2004, 01:12 AM Thread Starter
Just like the subject says...I want to make sure I put it in the right place before installing...
Thanks...
Laser Red 1998 Mustang GT - Daily Driver, 5spd, Leather, Mach 460.
Reef Blue '93 LX 5.0 5spd
New 306, AFR 165's, FTI cam, Tmoss Performer Intake, Scorpion 1.6 RR's, 30lb injectors, Pro-M 75mm MAF, FRPP 65mm TB, Kirban AFPR, BBK Longtubes w/ matching H, Flows, 3:73's, Steeda Tri-ax, Mac Cai, Black Magic Fan, Griffin Radiator, 3g Upgrade and more...
Sold
Performance Red 2000 Mustang GT - Mac Catback w/ 3.5in tips, Prochamber, Pro 5.0 shifter, 01 Hood Scoop, White Face Guages and 17x9 Chrome Cobra R's
5spd GT is offline
post #2 of 12 Old 07-24-2004, 02:02 AM
raceoholic330's Avatar
Trader Feedback: (46)
it goes in the thermostat housing on the lower intake directly to the left of the distributor. There's 2 bolts holding on the housing where the upper radiator tube goes into the lower intake. Remove the two bolts and the housing, and your t-stat will be right there.
-Scott
88 GT
Turbocharged Dart 331 & complete resto in the works...
raceoholic330 is offline
post #3 of 12 Old 07-24-2004, 11:29 AM Thread Starter
I know where the T-stat is...I just need to know where the best place to put the gasket is...so I don't have a leak...
housing/gasket/t-stat/manifold?
housing/t-stat/gasket/manifold?
Thanks...
Sold
5spd GT is offline
post #4 of 12 Old 07-24-2004, 03:10 PM
Ray III's Avatar
Fist clean off gasket surfaces with sandpaper or 3m Scotchbrite hand pad (or scotchbrite pad on power tool if you have one).
Insert t-stat in housing.
If the gasket has a sticky side on it, peel off the backing and stick it over the t-stat, otherwise use gasket glue on it to secure it to the t-stat housing.
Apply a THIN coat of RTV to the exposed side of gasket, then bolt in place.
this post property of RAYMOND
Ray III is offline
post #5 of 12 Old 07-24-2004, 03:21 PM Thread Starter
Thanks...the gasket is not sticky but I'll use just a bit of RTV to keep in place to bolt it up...
Sold
5spd GT is offline
post #6 of 12 Old 07-25-2004, 01:27 PM
Michael Yount's Avatar
If you've already got it in place - then ignore the rest of this post. The adhesive gasket is designed to hold the t'stat up in the housing when you're bolting the housing back to the manifold. It's REAL easy for the t'stat to pulled down by gravity, and if even a tiny bit of it wedges between the manifold and t'stat housing, you'll have a leak. I use only the adhesive backed gaskets for that reason.
Michael Yount is offline
post #7 of 12 Old 07-25-2004, 07:43 PM
Neil's Avatar
To hold the thermostat in the water neck while installing, loop a rubberband through the thermostat and slide a pen throught the loops on the outside of the waterneck. Get the bottom bolt in and almost snug then pull the rubberband out.
89 GT (original owner)
Dyno 260 RWHP, 306 ftlb (stock cats)
13.51@102.2 on BFG DR
GT-40 long block, GT-40 iron heads, B cam, GT-40 intake, 24lb inject, 155 pump, 65mm TB, 75mm Pro-m, BBK fenderwell, MAC 1 5/8 unequal, BBK cat h-pipe, MAC muffs, pullies, 31x19 Griffin, 3:55, B springs, KYBs, Kenny Br subs, Ford HD UCA, Maximum Motorsport: LCA, strut tower& CC plates, aluminimum shaft, Tri-ax, Cobra R hood, Cobra rear bumper cover, Konig Monsoon wheels.
Neil is offline
post #8 of 12 Old 07-25-2004, 08:02 PM
Novel idea - on my t'stat housing there is no bottom bolt - they are on each side....
post #9 of 12 Old 07-26-2004, 10:47 PM
Shifter's Avatar
Trader Feedback: (191)
GOOD F'ING IDEA NEIL!!!!!!!!!!!!!
I love little things like that.....
Shifter is offline
post #10 of 12 Old 07-27-2004, 03:43 AM
hardcore302's Avatar
Ugh, I couldn't get any sticky gaskets, and I had to do it twice because the stat kept faling down during the installation.
2007 black GT- JLT2 w/ Brenspeed tune, FRPP X, Edelbrock mufflers, GMS strut brace, BMR UCA, LCA's, panhard rod, Summit A-arm brace, baby seat.
hardcore302 is offline
post #11 of 12 Old 07-28-2004, 05:51 PM
Trader Feedback: (18)
Weird...I always put the stat in the intake manifold and then put on the gasket. Then the water neck with some silicone on the sealing surface.
I guess it works both ways.
ndmp40 is offline
post #12 of 12 Old 07-28-2004, 06:18 PM
If you look closely, the housing has a recessed area cast in it with a detent at the top, that allows the t'stat to be recessed in the housing, and the detent keeps it from rotating; this keeps the air bleed fitting at 12 o'clock. All of that's true for the better t'stats - the really cheap ones usually aren't shaped to fit the detent (they're just round), and they also don't have the bleed valve. If you have that kind of t'stat - that's what the adhesive backed gasket is for - put the t'sat in the recess in the housing, slap the adhesive gasket over it (holds it in place), and then simply bolt it on with no worries about it slipping, or rotating the bleed valve to some location other than the top.
