Rear Wheel Horsepower to Flywheel Horsepower Conversion - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 13 Old 08-13-2003, 04:09 PM Thread Starter
Question Rear Wheel Horsepower to Flywheel Horsepower Conversion
Just curious...I know most Dyno Test report the Rear Wheel HorsePower value. How would you calculate flywheel horsepower? In other words, how much flywheel HP would 300 RWHP be with a manual transmission? Is there an easy formula? Thanks.
Auto Reverse is offline
post #2 of 13 Old 08-13-2003, 04:13 PM
speed demon's Avatar
The average manual trans will lose 15-17% drivetrain loss.
91 gt 351
speed demon is offline
post #3 of 13 Old 08-14-2003, 10:20 PM
No easy or definative formula, just consider ~15% for manual and between 20-25% for autos. But the RWHP is more important anyway because that's how much HP is accelerating the car/reaching the ground.
ChewyR is offline
post #4 of 13 Old 08-15-2003, 11:32 AM
TRU DAT.... FLYWHEEL HP DONT MEAN ****E. IF IT AINT AT THE WHEELS THEN DONT WORRY ABOUT IT. BUT 300RWHP EQUALS ABOUT 345 FLYWHEEL.
BOTLFED S281 is offline
post #5 of 13 Old 08-15-2003, 01:13 PM
Banned
If you go with 15% for manual and 20% for auto, divide the rwhp by .85 for manual and .80 for auto. 300 rwhp would equal 352.9 flywheel hp manual or 375 auto.
In my case I'm making about 368 flywheel hp. Before I went to the dyno, I added up the minimum claimed hp increase for each of my mods and it came to 370 hp. I was pretty impressed it was so close.
post #6 of 13 Old 08-15-2003, 01:40 PM
Formerly BLOWN1989SALEEN
Scott_0's Avatar
hey guys does this make as much sense to you as does me? i read in 5.0 a little while back, say you have a car that makes 500RWHP with a C-4 behind it, well with your 20% that puts you at 588 FWHP correct? now lets say you have a 300RWHP with the SAME C-4 with the 20% loss that puts that motor at 352 as stated above. now does it make sense to you that a 500RWHP car looses 88HP and the 300RWHP car looses only 52?????? i dont go with the 15% and 20% figures, why in the world would a motor making MORE power loose MORE power than a motor making LESS power????? to me and as 5.0 said too i think the actual lose is more like 30-35HP for a manual car and 40-45 for a auto car, it just makes more sense to me.
Scott
2011 Ingot silver GT Brembo package, SVE drifts 19x9.5, Steeda Pro Action struts/shocks, FRPP K springs, GT500 strut mounts, BMR panhard adj. bar, Hushpower axle backs, Bama tuned
Scott_0 is offline
post #7 of 13 Old 08-15-2003, 02:03 PM
Banned
One of these magazines needs to test this and be done with it. I understand what you're saying BLOWN1989SALEEN, but I've also heard the argument that internal friction and other forces go up with added hp. The truth is probably somewhere in the middle.
post #8 of 13 Old 08-15-2003, 03:17 PM
Scott_0's Avatar
yeah never thought about that hey man i see your right down the road from me. im right in oxford, pa im like maybe 25min from hockessin, de. you go to cecil much?
Scott
Scott_0 is offline
post #9 of 13 Old 08-16-2003, 04:26 AM
Slo86GT's Avatar
No way around it. With my RWHP, my car's still a slug.
- Jody -
1986 Mustang GT MT - Toy
2003 Mustang GT Auto - Wife's DD
2013 Focus SE 5Door MT - Babymobile
Slo86GT is offline
post #10 of 13 Old 08-16-2003, 09:50 AM
Wink
BLOWN1989SALEEN is correct. %of power doesnt really work. Hp loss also varies by what automatic your running. A c6 will absorb more hp than a c4. So it would be hard to make a list of the loss for every transmission. BLOWN1989SALEEN numbers are as close as any.
djs! is offline
post #11 of 13 Old 08-16-2003, 12:05 PM
and flywheel does not = what hp your block is making.a blower producing 14 psi can draw 50-80 hp off your crank,add accys and your 400 rwhp car can have a motor thats actually producing
550- 600 hp - power adder,accy, and drivetrain loss.imagine that out of a stock block
2000 Ranger,explorer 5.0(dead,410 comming),powerdyne 9 psi,TFS heads,1087 cam,42lbs,FMS headers,Custom X-pipe ,BBK 75mmtb, ProM 87mm maf 4.10's with 30.5" tires,4r70wlevel10,pi multi 3500,98 ecc V with sct pro racer.
fauxexplorer is offline
post #12 of 13 Old 08-18-2003, 07:22 AM
Banned
No, I don't run my car. I'll be showing it at the Winner Ford car show in Newark in Sept. though.
post #13 of 13 Old 08-18-2003, 01:25 PM
I made 560hp all motor at the wheels. Thinking that's around 700hp at motor with C-4 trans. with 3;73 gears I run 9.80's.
www.naturaloutlaws.com
427coupe is offline
