????Which Cylinder heads for a 408 stroker???? - Ford Mustang Forums : Corral.net Mustang Forum
View Poll Results: ????Which Cylinder heads for a 408 stroker????
Brodix Track 1 0 0%
TFS High Ports/TFS R Series 7 23.33%
TFS Twisted Wedge 0 0%
AFR 205/AFR 225 18 60.00%
Dart Sr. (I have one laying around) 0 0%
Victor Jr. 3 10.00%
Victor Sr. 1 3.33%
Canfields 1 3.33%
Voters: 30. You may not vote on this poll
post #1 of 6 Old 08-07-2003, 05:03 PM Thread Starter
DaOnE51T's Avatar
Question ????Which Cylinder heads for a 408 stroker????
Im planning on building a 408 stroker motor for my race car. I was wondering which head should I buy? Im looking for a head that is capable of handling 650hp at the motor or more.
Here is my plan:
72" 351w block
.030 over
Scat 4340 4.000 crank
Scat 4340 H-beams
Je Pistons 12:1 or more
FTI custom solid roller cam
Victor intake
Custom Biggs carb
THANKS, PEACE 1
Bad Intentions Motorsports, The secret is the tune!!!
DaOnE51T is offline
post #2 of 6 Old 08-07-2003, 11:31 PM
306
Trader Feedback: (18)
AFR 205s.
1989 LX Hatchback.
1984 Pro-street Ranger.
306 is offline
post #3 of 6 Old 08-10-2003, 07:09 PM Thread Starter
DaOnE51T's Avatar
DaOnE51T is offline
post #4 of 6 Old 08-10-2003, 09:28 PM
I'll be running a set a Bennet Racing Stage III High Ports with my 410ci motor. Car will be complete in a couple months. Before it came apart it I ran a set of Canfields. It made a best of 453rwhp with those. With more compression and the bigger TFS's I'm hoping for 510+rwhp. The set up is EFI, with a Super Victor Spyder intake. Big solid roller too.
4"
4" Stroke is offline
post #5 of 6 Old 08-10-2003, 11:36 PM
Badboss351's Avatar
I am running race ported Jr's on my 410, and should have some times Friday night. Motor should be making around 650-700hp, and over the 1,000 mark on juice. I'll post times on here, hoping everything goes well. Had alot of problems to workout from last time, so hopeing for good times.
Greg(XSR)
XSRcylinderheads built nitrous 445".......5.32 @ 136 w/1.30 60ft (best 60 to date is 1.252)
Badboss351 is offline
post #6 of 6 Old 08-11-2003, 12:59 AM
Lee8995's Avatar
Gonna get flamed for this but here it goes.
If your looking for out of the box performance then I would list them like this.
AFR 205/225
TFS "R"
Victor Jr
Brodix Track 1
If your looking for a head that has hidden potential via porting then heres how I would stack them up.
AFR 205/225
TFS "R"
TFS high ports
Victor Jr
World Windsor Sr/Roush 200
Brodix Track 1
Canfields
Race Only goes to the Edelbrock Victors If you can afford the shaft mounted rockers.
I personally see the Std. Twisted wedge head as being too small without major port work, But they are a good head. The Canfields are a good head but have had some problems when extensive port work is done.
The real reason that we can't have the Ten Commandments posted in a courthouse is this:
You cannot post 'Thou Shalt Not Steal,' 'Thou Shalt Not Commit Adultery,' and 'Thou Shall Not Lie' in a building full of lawyers, judges and politicians...It creates a hostile work environment.
Lee8995 is offline
