Whats the best way to Remove Distributor gear and Shaft?? - Ford Mustang Forums : Corral.net Mustang Forum
Old 08-05-2003, 06:38 PM   #1
S-Trimmed302's Avatar
Trader Feedback: (96)
Hey guys Im ready to mount a new Pickup coil and Module on my Stock distributor..I have Both Pins knocked out of the Distributor shaft but I cant get the Distributor gear off to save my life..What is the best way to get the Gear off without damaging it..I need this Distributor apart tonight so I can change its Pickup ASAP..BTW, Yes the Distributor is Part of the Engine so thats why I posted it in this Forum Mods ..Thanks for any help..!
Jeff
S-Trimmed302 is offline
Old 08-05-2003, 06:39 PM   #2
BobCat's Avatar
I've never been successfull getting one off without a press.
__________________
94 GT 327 S-trim 4r70w yadda yadda
http://www.STLMustangs.com
BobCat is offline
Old 08-05-2003, 06:41 PM   #3
A Press to get the Distributor gear off?
Old 08-05-2003, 07:11 PM   #4
Member
I tried doing the same thing, I got the pin of but I could take of the gear. There is a tool to take it off, but you need to find a machine shop to put holes in your new dist. gear. The one I bought from FRP didnt have one. Ask you machine shop and see if you even have to. It should cost more than like $30
Good luck
James
james51381 is offline
Old 08-05-2003, 10:07 PM   #5
James,
Im not installing a Brand new Gear on the shaft..I just need to remove the factory steel gear so I can disassemble the Distributor and replace the Pickup coil under the Rotor..The pickup is the Part that the Modules 3 plugs slide into..After im done, I just need to put the Factory stel gear back on it and Start the car.. Thanks for the Input guys..
Jeff
Old 08-06-2003, 01:06 AM   #6
BobCat's Avatar
you will still need a press to get it off
__________________
BobCat is offline
Old 08-06-2003, 01:55 AM   #7
stinkin' Lincoln's Avatar
take it to your local machine shop and say, "here, do this"
stinkin' Lincoln is offline
Old 08-06-2003, 08:51 AM   #8
C. Johnson's Avatar
If you do it yourself, make sure you go get some new roll pins. Puter did mine for me and he had a press. Mark the housing and gear before popping it off as it is tricky to get it all lined back up and you definitely dont want to have to press it off and on multiple times. If you don't want to fool with it, do as these guys say. Take it to a machine shop and let them do it. The charge would be minimal I am sure.
Casey
__________________
-- Casey
1989 GT
2009 Mazda Speed 3
2006 Mazda Speed 6 (wife's car)
C. Johnson is offline
Old 08-06-2003, 09:38 AM   #9
Corral Member
neckdemon is offline
You may not post new threads
You may not post replies
© 2010-2011 Corral.net
