Piston ring sizes for stock 5.0? - Ford Mustang Forums : Corral.net Mustang Forum
Old 07-08-2003, 12:16 AM   #1
What are the piston ring sizes for a 5.0L for 1994? I'm looking through the summit website and there are a ton of combinations for each ring type.
My plans are to re-hone the cylinders at home - do I still go with the standard 4.00" rings? I'm new to rings so please be easy on me.
Thanks!
Stang94GT is offline
Old 07-08-2003, 09:08 AM   #2
Member
If you are just doing a basic re-ring, you will need the standard 4.00" rings and the compression rings are 1.5mm thick with the oil ring being 4.0mm thick. I'm not sure what brand ring you want, but I know the part numbers for Sealed Power rings. The standard plain rings are E458X, and the part number for the moly rings is E458K. Hope this helps you out. Any other questions just ask.
__________________
94 GT---CHP 347, Windsor Jr. heads, 24 lb inj., Pro-M 75, Crane 2020, Explorer intake & TB, Harland Sharp RR, Paxton FPR, BBK shorties, O/R H pipe, Flowmasters, 3.73 gears, NOS 5115
FI347GT is offline
Old 07-12-2003, 11:05 AM   #3
I'm not sure that these rings will be able to take my 12psi of boost. What do you think?
Old 07-12-2003, 11:16 AM   #4
Get some Sealed Power or Speed Pro rings. I read a buildup in which they used 1 of the 2 on half the cylinders and stock replacements on the other 4...they had 0% compression loss after the break-in whereas the stocks had some minimal compression loss.
__________________
2002 True Blue Lightning (mines), Bassani Cat-back, Metco 4lb lower, wickdsvt ported eaton, JLT CAI, Ed Clark SCT Tune.
409hp / 476tq
12.55@108 (before ported eaton)
2004 Azure Blue Mach I,(dads)
Mac Cat-back, JLT CAI, Pro 5.0 shifter
motorv8ed is offline
You may not post new threads
You may not post replies
© 2010-2011 Corral.net
