Why does my fuel pump fuse keep blowing??? - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 10 Old 06-07-2003, 10:51 PM Thread Starter
So what causes fuses to blow? Cause this is the second time the fuse blew and I can't start the car because of it because the fuel pump isn't pumping fuel? So what can it be.....bad fuel pump, bad ground???? help. thanks
Red 95GT: B50 317", P1SC (3core), AFR 165's, blower cam, Cobra Intake, 65mm TB, 75MM MAF, 42#ers, 255lph, 1.6rr's, 3.73's,
Neo95gt is offline
post #2 of 10 Old 06-08-2003, 02:35 AM
Maybe the fuel pump relay? Or a shorted 12+ wire?
John
"Mustangs Rule! Calculus Blows!"
BBK LTs, BBK X pipe, Accufab Plenum & TB, UDP, 3.73s, Tri-Ax shifter, Haywood Custom Speed Tune
Looking to get a 2003 Cobra soon!!
Stang88AODGT is offline
post #3 of 10 Old 06-08-2003, 09:01 AM
Rich G's Avatar
Trader Feedback: (35)
I know this dont solve the problem, but you could put a breaker in, this way you can just reset it
Rich G.
Rich G is offline
post #4 of 10 Old 06-08-2003, 11:38 AM Thread Starter
Neo95gt is offline
post #5 of 10 Old 06-08-2003, 04:04 PM
where is the fuel pum relay located in a 88 gt?
oohwe306 is offline
post #6 of 10 Old 06-08-2003, 06:54 PM
Grn92LX's Avatar
Trader Feedback: (21)
I never heard of a fuel pump fuse?? Where is it located?
Grn92LX is offline
post #7 of 10 Old 06-08-2003, 07:18 PM Thread Starter
yea it has one.....its one of the fuses in the power distribution box. so it could be from a bad relay??? where the hell is the relay on the fuel pump wiring?? this is getting annoying i put in a new fuse and after like 10minutes of driving it just blows again
Neo95gt is offline
post #8 of 10 Old 06-08-2003, 07:55 PM
Rich G's Avatar
the really is under the drivers seat
Rich G.
Rich G is offline
post #9 of 10 Old 06-08-2003, 08:16 PM Thread Starter
i don't think it is for the 94-95 models.......anyone know where the fuel pump relay is on my car??
Neo95gt is offline
post #10 of 10 Old 06-08-2003, 08:34 PM
Rich G's Avatar
should be by the mass air on the fenderwell
Rich G.
Rich G is offline
