Car won't stay running - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 13 Old 04-08-2003, 10:08 PM Thread Starter
When I go to start my car it turns over right away, and you can hear it start up but after a second or so, it shuts right off. So far i've changed the Fuel filter, and I just a bought a new fuel pump which I am gonna replace soon, but does anybody else know what could be causing this, or has this happened to anybody else before.
The day it happened, the car started up fine in the morning, then I drove it down the street for about 10 min, went up the street to talk to somebody, and as I was leaving my car was hesitating to start, then it died. We found out that the problem with that was my power cable going to my starter had a bad ground, so we fixed that problem, but as i mentioned before, now when I start the car, it turns over fine but doesn't stay started and shuts right off as if it's bogging out.
And there is gas in the car ...so if anybody knows what could be causing this problem just let me know.
~Aaron
SkunkApe is offline
post #2 of 13 Old 04-08-2003, 10:50 PM
The Black Knight's Avatar
check the small wire coming off the batt- going to the computer
89 GT 5.0 HO 5spd 3.55 rears//190lph, ultra coil, =length shorty headers,ORHP 2.5 muffs,sub frame conns,pulleys,rear discs,KC clutch,75HP zex,batt moved,cobra rims,alum FW
04 GT stock AT
The Black Knight is offline
post #3 of 13 Old 04-08-2003, 11:21 PM
MnIrishJr's Avatar
try holding the clutch in, or take it out of gear ---duhh
busten chops whats up bro call me
11' 5.0 Brembo TVS trapping 130+
89' 331 Stroker Carb'd
Frame up resto!
370/375 at 2950 lbs
MnIrishJr is offline
post #4 of 13 Old 04-09-2003, 11:31 AM Thread Starter
Anybody with any other suggestions?....this is killing me
~Aaron
SkunkApe is offline
post #5 of 13 Old 04-09-2003, 11:44 AM
l@SF's Avatar
need a little more than it turns over, are you getting spark, do you hear you injectors firing when you key is turned to the on position, whats you fp, does the car sound like its going to start or does it just crank ?
you might want to look at your tfi module
lots-o-scrap with a procharger
l@SF is offline
post #6 of 13 Old 04-09-2003, 11:54 AM Thread Starter
I do have spark....i was told that my fp is crappy....not getting what i should...and the car does start up but for only a second or two then just bogs out and shuts off
i'm going to change the fuel pump as soon as i have time, becuase the only thing i can think of is that the car isn't getting enough fuel to stay running
SkunkApe is offline
post #7 of 13 Old 04-09-2003, 11:57 AM
l@SF's Avatar
you might not have enough pressure to fire the injectors, if you have a gauge you should be between 27-30lbs on the rails
l@SF is offline
post #8 of 13 Old 04-09-2003, 10:47 PM
StreetFighter Racing's Avatar
Thumbs down
buy a new car
For Sale: CNC Canfield Heads ,Ported Intake & exhaust, 64cc, 2.020-1.600 Severe Duty valves, 200cc port volume, Bronze guides,Plus MORE ,1.6 Scorpion R/R. complete $1250
StreetFighter Racing is offline
post #9 of 13 Old 04-09-2003, 10:50 PM
Aaron i'm only joking, i'll help you thisweekend. i think its your fuel pump.
post #10 of 13 Old 04-09-2003, 11:36 PM
its your pump.. mine did the same thing drove to work and when i go to leave at the end of the day i get about 150 yds downt the road and sputter with no gas...
White '91 LX - 395.82 ci. not running yet.
Greg Lawrence is offline
post #11 of 13 Old 04-10-2003, 07:23 PM Thread Starter
When your pump was done for.....what did your car do when you tried to start it...did it start up and bogg out...or did it not start at all?
~Aaron
SkunkApe is offline
post #12 of 13 Old 04-13-2003, 09:16 AM Thread Starter
ok...well i changed the fuel pump and the fuel sending unit....and the car still doesn't stay running.......now me and some people are thinking that it's the module on the ignition......but does anybody have any other ideas?
~Aaron
SkunkApe is offline
post #13 of 13 Old 04-13-2003, 10:06 AM
could be fpr, see if you can keep it running w/carb and choke cleaner
slow87GT is offline
