Boost gauge reading 20 vacuum at idle, is that normal?? - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 19 Old 04-06-2003, 09:05 PM Thread Starter
I always figured this was normal, but then i read a few things and it seems that normal is a vacuum of about 10.....do i have a problem?
Red 95GT: B50 317", P1SC (3core), AFR 165's, blower cam, Cobra Intake, 65mm TB, 75MM MAF, 42#ers, 255lph, 1.6rr's, 3.73's,
Neo95gt is offline
post #2 of 19 Old 04-06-2003, 09:25 PM
Mr. Black's Avatar
What does your Zero read with the car off? If it's an Autom
Steve, 2015 Mustang EcoBoost Premium with Nav on factory 20s. Magnaflow Catback, MMR Intake.
2014 Suzuki Vstrom 1000.
06 Ford F350, PSD, CC, LB, 4x4.
02 Ford Taurus DOHC. 88 Suzuki Samurai.
Mr. Black is offline
post #3 of 19 Old 04-06-2003, 09:29 PM
Mr. Black's Avatar
If it's an Autometer gauge the needle should be in the box at Zero with the car off.
On mine with the stock cam it idled at around 14 inches and with the E cam it idles at around 10 inches.
post #4 of 19 Old 04-06-2003, 10:18 PM Thread Starter
with the car completely off it reads about 3 or 4 vacuum....but at idle its like 21.....my cam is nowhere near stock, but still i dunno why it reads so high?
Neo95gt is offline
post #5 of 19 Old 04-06-2003, 10:29 PM
Ian
Ian's Avatar
Sounds like a bad gauge, give Autometer a call, get an RMA and send it back...
Ian
Ian is offline
post #6 of 19 Old 04-06-2003, 11:47 PM
Coilz347's Avatar
my guage reads 2or3 with car off, and 20, 21 at idle
Coilz347 is offline
post #7 of 19 Old 04-06-2003, 11:57 PM Thread Starter
hmm well at least im not alone...anyone else?
Neo95gt is offline
post #8 of 19 Old 04-07-2003, 12:04 AM
Mr. Black's Avatar
The needle should be in the box with the car off. If it is not then send it back.
The zero is flexable within the box to accomodate for atmospheric conditions outside at any given time.
post #9 of 19 Old 04-07-2003, 12:08 AM
not nessesarily, my buddy evlbrd wth a blown 351 reads about 20 at idle
90 Mustang Gt Project (work in progress)
Mods so far:
Tokico Electronic adjustables all around (on sale in december), Eibach lowering springs (on sale in december), granatelli weight jackers (on sale in december), mac uppers, hurst shifter, the 10 minute mods, mac CAI, 65 mm tb, 73 mm MAF, under drive pulleys, MM full length subframe connectors, CC plates, 16 1/2 degrees of inital timing with 91 octane shifting at 6 grand, not one detonation
, Stock Track-Lok rebuild and 3.55's.
Upcoming mods:
- MM Maximum Grip package
-Track heat intake
-some alluminum heads
-blower
-6 point cage
-big brakes
5LfromHELL is offline
post #10 of 19 Old 04-07-2003, 09:21 AM
Formerly BLOWN1989SALEEN
Scott_0's Avatar
my TFS stage1 cam reads 10in. @idle
Scott
2011 Ingot silver GT Brembo package, SVE drifts 19x9.5, Steeda Pro Action struts/shocks, FRPP K springs, GT500 strut mounts, BMR panhard adj. bar, Hushpower axle backs, Bama tuned
Scott_0 is offline
post #11 of 19 Old 04-07-2003, 10:37 AM
mine reads zero with car off about 11-13 at idle. It should be zero with the car off, sounds like a bad guage to me
Kyles89GT is offline
post #12 of 19 Old 04-07-2003, 10:40 AM
twofast's Avatar
mine reads 19-20in at idle, but i have a stock cam. (it reads 0 when the engine is off)
68 coupe
351W PT-88 E-98
700hp/643tq 9.61@145
radials/street driven
twofast is offline
post #13 of 19 Old 04-07-2003, 11:54 AM
swinerton's Avatar
Trader Feedback: (15)
TFS Stage 1
0" engine off
11-12" engine running
Cory Swinerton
2013 Boss 302 #540 712rwhp/592rwtq (SOLD)
1999 GT 2V 775rwhp Ysi, Boss 304". (SOLD)
Originally Posted by WhiteLX408 View Post
Running street tires at the track is like wiping your ass with a turd.
swinerton is offline
post #14 of 19 Old 04-07-2003, 12:33 PM
straightliner1's Avatar
Not the same gauge but I have a defective fuel pressure gauge I just sent back that when completely bled down it still reads 20 psi or so. Obviously when fired up my F/P reads 20 psi high. Is this a Pro Comp fluid filled gauge by any chance?
Another vote for send it back.
Justin
straightliner1 is offline
post #15 of 19 Old 04-07-2003, 09:38 PM Thread Starter
umm its just a regular autometer mechanical boost gauge.....silver on silver. i wonder if its bad, i mean at idle it sits at like 20, but with a real small touch of the pedal it goes to 10 easy, hmm im confused
Neo95gt is offline
post #16 of 19 Old 04-08-2003, 02:03 AM
What does it read with the car off?
Justin
post #17 of 19 Old 04-08-2003, 12:41 PM Thread Starter
alittle under zero
Neo95gt is offline
post #18 of 19 Old 04-08-2003, 03:43 PM
17-20 in. Hg at idle. (850 rpm'S)
0 in. Hg. off
I have the autometer phantom 30 in Hg- 20 psi boost and a stock cam and s-trim.
Please realize that vacuum is dependent on idle rpm's. Lower idle rpm's result in lower vacuum. maybe you're idleing a bit high. Also, It's notmal to see a decrease in vacuum when you rev it up a bit. However, if you're not seeing zero when the car is off, then the gage needs some attention.
donjuan is offline
post #19 of 19 Old 04-08-2003, 05:36 PM
here it is
normal is 17- 22
normal for the stock cam is 18-21
if you advance the timing, you get more vaccum. mine stays around 20.
you should check for an intake leak or leak in the vacuum tubing to the gauge. auto meter gauges never read right, but if its that far off, i dont think its the gauges fault. my gauge read 14 psi when i was running 17 and it read 20 inches during a heavy deceleration when it should read 25. enjoy.
latre,
jordan
1990 Stang GT
402 (4.00x4.00) engine w/ 8.5:1 compression, W351 svo block, arias custom forged pistons, 4340 eagle crank and h-beam rods
Ported TFS TW heads, dual springs, forged 1.6 rr's, link bar hydrolic rollers, billit custom (bigish) crane cam
80mm C&L MF, 95mm Holley TB, cobra intake
1 5/8'' jba headers, 2.5" strait pipes to flow bastards w/ turn downs
tremec 3550, 3.73 rear end, steeda shifter
kirban AFPR, Lucas 38 lb injectors, 255 holly intank, bosch high flow pump
accel billit distributor, crane wires, PS-92 coil, HI-6R ignition
PMS, mark VIII fan
Drag bags, 275/60-15 BFG DR's
and oh ya . . . a ProCharger.
as they say, "heaven is being stroked and blown."
evilbird is offline
