What is the PIP sensor? - Ford Mustang Forums : Corral.net Mustang Forum
Old 03-25-2003, 05:29 PM   #1
What is the PIP sensor and how much is it? I had a problem where the temp was up a little but the car died and wouldn't restart till it was cooled a little. Any ideas?
Thanks,
Bret
__________________
1988 LX 5.0 Hatchback
2 chamber Flowmasters
Cold Air Intake
24 lb Injectors
C&L 76mm MAF for 24's
FMS 3.73's
Aeromotive FPR
Walbro 190lph
SD to MASS Air (A9P) Convert
70mm TB
CompCams Polymer Intake
http://www.stangsofocala.com
Bret Macolino is offline
Old 03-25-2003, 05:51 PM   #2
The Ignition Module is getting hot. That is the little grey box on the distributor.
Take it off and put some heatsink compound on it.
If it still does it, then you need to get a new one.
__________________
Resident grump and smart...
damage is offline
Old 03-25-2003, 06:01 PM   #3
PIP sensor is what the EEC uses to measure the RPM of the engine. Like the guy above said, it sounds like your TFI module is going bad and needs to be replaced. Its located on the side of the distrubutor and has a wiring harness going to it.
st515O is offline
Old 03-26-2003, 02:45 AM   #4
US Air Force Active Duty
Notch Rocket's Avatar
Don't be so sure. I just fixed this same problem in another recent thread. TFI module was fine, the PIP (Hall sensor or pickup coil) inside the distributor would go bad after getting to engine operating temperature, basically getting heat-soaked.
__________________
Click here to see my Notch
Nitrous is like a hot hooker with a STD. You know you want to hit it, but are afraid of the consequences.
Notch Rocket is offline
You may not post new threads
You may not post replies
© 2010-2011 Corral.net
