#1 |
Hi, I lucked out and found a roller 351w from a 95 lightning that I'm having rebuilt for my Mustang. The guys at the local parts store told me that in their books for the pistons it only goes up to 93. And even on the pre 93 pistons there is a side note that says except lightning. So, My question is. Is there a difference between lightning pistons and regular 351 windsor pistons? If there is a difference what is it? Could I use regular 351w forged pistons in my lightning block? Thanks....Marc
__________________
95 Lightning 351w 30 over, H beams, Probe pistons, balanced assy. Edelbrock heads 2.02/1.60 valves, Crower 15512 cam, GT-40 intake, 75mm T/B, 42 lbers, 80 mm C&L, BBK 1 3/4 L/Ts, Novi 2K, center force d/f clutch, 3.73s and a factory T-5. All in a 92 vert. |
| Sponsored Links | |
Advertisement |
#2 |
The 1st Gen. Lightnings 351W used a dished piston and had a Comp. Ratio of only 8.8:1. w/ the GT40 Iron heads.
Really depends on what you had plan to do with the engine and what CR. Being a parts store most of them usually sell a TRW/Sealed Power type piston, which are OK, but they are heavy slugs. JT
__________________
Stock short block, AFR 185's,XE274HR... "Tons of Suspension"... 11.69 @ 116mph on "Nothing but Atsmophere"...PRICELESS "Live Fast...Die Young...Leave a Good Looking Corpse" |
#3 |
So, I guess I could put any 351w piston in there as long as it's the compression ratio that I want? The lighter the better i'm guessing. Thanks...Marc
__________________
#4 |
Yes they do. All roller 5.8 blocks have the same pistons. My 1997 F-250 shortblock has the same pistons in a 1994 lightning motor. They have huge valve reliefs.
I had to mill my TFS heads down to 43cc's per chamber just to get a 10:1 CR.
__________________
1988 Mercury Cougar XR7 |
#5 |
So when I order pistons do I have to tell them it's a roller block? Or could I just get TRW 351w pistons for any year? ....Marc
__________________
#6 |
Roller block/ Non roller block doesn't matter. They still have same bore and stroke. Use same pistons
You will need a 351W piston for the later block with the 9.503 deck height. Are you planning on a cast replacement piston or going with a forged??? Let me know I have a Federal Mogul (TRW)/Speed Pro performance catalog for part #'s. What head is going to be used? JT
__________________
#7 |
I have Edelbrock Performer heads. With 202 valves. Let me know the part number or specs on the pistons. Thanks....Marc
__________________
#8 |
Also....I'm going with the forged pistons. I need a 30 over. ....Marc
__________________
#9 |
The L2446F30 would yield ya about 9.3:1 CR with that Edelbrock head. It consist of a .110 dish.
What CR did you want to be at. Is this N/A, blower etc.... I see you have used DSS shortblock in past. Have you considered there piston only kits. They would be somewhat lighter and more custom to your needs.
__________________
| Sponsored Links | |
Advertisement | |
| Bookmarks |
Previous Thread
Next Thread
| Thread Tools | |
| Display Modes | |
Linear Mode
