90 GT Cannot Pull Codes - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 20 Old 06-18-2017, 11:52 AM Thread Starter
I have a 90 Convertible with all brand new wiring. Engine harness is a Ron Francis Cobra-75 and the body harness is American autowire 87-89 fox body kit.
I can't pull codes. No code 11 nothing.
Capacitors look good. No burnt trace. If anyone can help me trouble shoot the wiring I'd appreciate it.
JV106 is offline
post #2 of 20 Old 06-18-2017, 06:06 PM
indy2000's Avatar
did they come with diagrams?
indy2000 is offline
post #3 of 20 Old 06-18-2017, 08:01 PM Thread Starter
No diagrams. Just instructions.
There's a connector that you plug in to itself to choose manual or auto transmission.
Otherwise it tells you which part numbers to use for sensors and ecm. I'm running an a3m.
JV106 is offline
post #4 of 20 Old 06-19-2017, 09:26 AM
indy2000's Avatar
let me have a look at the instructions then
in the meantime check to make sure you have a 5 volt ref circuit
indy2000 is offline
post #5 of 20 Old 06-19-2017, 03:31 PM Thread Starter
https://www.ronfrancis.com/images/COBRA75-INST.pdf
back probing the ecu harness at the computer from pin 26 to pin 60 I get 4.99V
JV106 is offline
post #6 of 20 Old 06-19-2017, 03:39 PM Thread Starter
http://www.americanautowire.com/PDFL...20IN%200.0.pdf
Here's the body kit instructions.
JV106 is offline
post #7 of 20 Old 06-19-2017, 08:37 PM
indy2000's Avatar
how are the two harnesses connected?
indy2000 is offline
post #8 of 20 Old 06-19-2017, 09:08 PM Thread Starter
12v ignition comes from the body harness.
Coil connection came from engine harness I tied the tach neg connection from the body harness to it at the coil.
12v crank only runs to the s terminal of starter solenoid.
CEL neg runs to ecu
CEL pos runs to body harness
Vss runs to ecu harness. Electric speedo is t-tapped to vss positive.
Clutch safety switch comes from body harness and I haven't seen where it interacts with the ecu harness. I have it looped to itself - not connected to clutch switch.
JV106 is offline
post #9 of 20 Old 06-20-2017, 08:48 PM
indy2000's Avatar
if you have the 5 v ref
and you have good power and grounds to the ecm, ecm is the only thing left
I have a reservation, because I do not have a wiring diagram in front of me, and they don't supply one
so have to assume its the same as stock
indy2000 is offline
post #10 of 20 Old 06-21-2017, 10:28 AM
tmoss's Avatar
Trader Feedback: (48)
Check this circuit for what trans you have. I'm pretty sure the manual neefds the NDS circuit to read codes.
Tom Moss
tmoss is offline
post #11 of 20 Old 06-23-2017, 09:42 PM Thread Starter
I monkeyed around with it at some point and moved the wire that was supposed to go to pin 48 at the ecm. Got it back to the pin 48 and now I can pull codes.
Now I need to fix a slight misfire.
Thanks for yalls replies.
JV106 is offline
post #12 of 20 Old 06-24-2017, 03:29 PM
indy2000's Avatar
what cylinder?
indy2000 is offline
post #13 of 20 Old 06-24-2017, 10:09 PM Thread Starter
I'm not sure. I did the goose test, I think. It showed 8 on the reader and then rev'd up for a while, then came down. Never got a code after that.
JV106 is offline
post #14 of 20 Old 06-24-2017, 10:14 PM Thread Starter
How do you Indy, typically do a cylinder balance test?
I got koeo codes 11, 85, 10, 15.
Koer 8, 11, and 60 at some point.
JV106 is offline
post #15 of 20 Old 06-25-2017, 01:21 AM
indy2000's Avatar
after engine running codes are done
you have 2 minutes to quick snap to WOT to initiate balance test
indy2000 is offline
post #16 of 20 Old 06-25-2017, 02:24 PM Thread Starter
Koer
8 cylinder of course
11
Balance test
10 - cylinder #1?
JV106 is offline
post #17 of 20 Old 06-25-2017, 04:29 PM Thread Starter
Ran it again I got 20 and 10.
JV106 is offline
post #18 of 20 Old 06-25-2017, 04:51 PM
indy2000's Avatar
looks like
2 and 1 are not contributing
leak down and comp tests next
indy2000 is offline
post #19 of 20 Old 06-25-2017, 06:19 PM Thread Starter
Ok. Man I'll be heart broken this is a brand new 363.
What's the difference between compression and leak down?
JV106 is offline
post #20 of 20 Old 06-25-2017, 07:42 PM Thread Starter
I looked up the leak down test I don't have the tools to do that.
I have a very cheap compression tester that I do not trust. I checked cylinders 1, 2, and 5. They were all about 150.
If there's nothing else to check on my own I will have to go to a shop to do a proper leak down and compression test.
Thanks again for your help.
JV106 is offline
