Axle pros. Please look at this gear pattern - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 8 Old 06-17-2017, 09:08 PM Thread Starter
last5liter's Avatar
Recently got my axle back from the shop. Already there are multiple issues with there work.
Can anyone look at the gear mesh pics and tell me if they at least set the gears up correctly?
Laser Red 1995GT with a 408W
Best ET to date: 11.0@133
last5liter is offline
post #2 of 8 Old 06-17-2017, 10:09 PM
indy2000's Avatar
drive side looks ideal
coast is very acceptable
are these new or used?
indy2000 is offline
post #3 of 8 Old 06-17-2017, 10:23 PM Thread Starter
last5liter's Avatar
Yes all new parts
post #4 of 8 Old 06-18-2017, 12:25 AM
indy2000's Avatar
that is fine then
indy2000 is offline
post #5 of 8 Old 06-18-2017, 09:20 AM
10SECFox's Avatar
Pattern looks good, what are other issues??
10SECFox is offline
post #6 of 8 Old 06-18-2017, 08:47 PM Thread Starter
last5liter's Avatar
Well for starters....
The passenger side axle shaft is frozen. They assembled the nuts and bolts backwards on the strange engineering caliper brackets, most likely cause they ordered incorrect axles without access holes in them.... like most Ford 9" axles have.
I'm also not 100% sure they welded the 9" bearing ends onto the axle tubes correctly cause they look like there not centered on the tubes?
They also forgot to return my cobra caliper bracket I gave them as reference for the clocking of the calipers.....
Other than that it's seems fine lol
post #7 of 8 Old 06-18-2017, 08:54 PM Thread Starter
last5liter's Avatar
Pics
post #8 of 8 Old 06-22-2017, 08:26 AM
Most 8.8's that have been beat on are bent. When the 9" ends are welded on they are installed in a jig that corrects the bent tubes, it's very common for the ends to appear crooked.
Sprayn383 is offline
