What's this hole? (have leak and not sure from where) - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 7 Old 06-16-2017, 09:49 AM Thread Starter
50jeff's Avatar
I'm getting what looks like maybe coolant pooling up a little bit at the very back of my block in a valley below the PCV valve and at the bell housing....and it's enough to slowly drip down the side of bell housing, etc. But right next to it is a hole with threads in it...but it's very hard to see back there and before I pulled everything off I wanted to see if anyone knew.
The coolant gets into the hole...but it could just be I have a gasket leak and it's flowing from that little valley into the hole (which is my guess). So #1, what's that hole and should it be plugged? #2, what gasket would be leaking back there typically? My passenger side head maybe?
Thanks!
'93 GT – Intercooled Procharger, TW 11R 190 Heads, Holley SysteMAX II, FTI Custom Cam, 3500 Stall Conv., Long Tubes/Flowmaster, Detroit Truetrac Diff/3.73’s/Moser Axels, Bilstein Suspension, Steeda Lowering Springs/Control Arms/Caster Camber Plates/Subframe Conn./TB Plates
50jeff is offline
post #2 of 7 Old 06-16-2017, 10:04 AM
More than likely an intake gasket leak. The hole I'm not sure either a un used hole or ur missing a bolt.
bojo is offline
post #3 of 7 Old 06-16-2017, 11:36 AM
Flyin Ryan's Avatar
Trader Feedback: (38)
The only thing in that area that I can think of is one of the coolant lines from the egr spacer that goes to the lower intake and the other goes to the heater pipe
Originally Posted by blue93hatch View Post
I spec'd my whole build to fit a cold air intake I had
Flyin Ryan is offline
post #4 of 7 Old 06-16-2017, 05:29 PM
steel1's Avatar
Trader Feedback: (59)
Think it might be a blind hole.
since it's in a tough spot I would get a piece of tie wire bend it so you can probe and see if the hole is blind.
steel1 is offline
post #5 of 7 Old 06-16-2017, 06:04 PM
Thats a blind threaded hole on the block. Used for grounds or wire loom clips etc..
630-462-3978 Shop Direct
877-723-5487 Shop Toll-Free
TONS of Build Photos Ck at
Make sure to sign up for
strokeme is offline
post #6 of 7 Old 06-17-2017, 04:36 PM Thread Starter
50jeff's Avatar
Cool thanks a lot guys! I'll pull of my lower intake as I probably do have a gasket leak then. Just wanted to make sure no related to the mystery hole. Thanks!
50jeff is offline
post #7 of 7 Old 06-17-2017, 04:56 PM
That hole is present on some blocks and not on some blocks but it has nothing to do with your leak whatsoever.
strokeme is offline
