Drilling a hole in the body plate..to cure SURGE - Ford Mustang Forums : Corral.net Mustang Forum
 6Likes
  • 1 Post By Paulie
  • 1 Post By kjb302ho
  • 1 Post By indy2000
  • 1 Post By Bossxr8
  • 1 Post By fasterthangas
  • 1 Post By TomR
post #1 of 11 Old 05-17-2017, 07:17 PM Thread Starter
I have heard from a couple of people that drilling a small dia hole in the throttle body plate will help cure idle surging.. Is there any TRUTH to this? If so, what dia and where do you drill it?
2012 BOSS 302 Laguna Seca w/boost
2004 Cobra VertTriple Black, STOCK
65 Fastback A code.69 Mach 1 428 SCJ Drag Pak 4(SALE)
93 Reef Blue coupe...pretty much stock.
ulev1st is offline
post #2 of 11 Old 05-17-2017, 07:25 PM
Is the car tuned?
fasterthangas is offline
post #3 of 11 Old 05-17-2017, 07:38 PM Thread Starter
Basically a stock 93 5.0 with Cobra intake, Cobra EEC, Cobra injectors and Cobra mass air.. E cam and full exhaust.. no other mods.. NO TUNE
ulev1st is offline
post #4 of 11 Old 05-18-2017, 12:41 PM
Paulie's Avatar
No. Drilling a hole is no different than adjusting the throttle stop.
TomR likes this.
1990 LX, HCI, S-trim
Paulie is offline
post #5 of 11 Old 05-18-2017, 12:43 PM
Ford used to sell a plate with an adjustable orifice in it to dial out some surge. I haven't seen them in years, but they exist.
Was called an Idle Bypass Plate
idel bypass plate(for surge fix)..who uses it?
Buy one new.
https://lmr.com/item/LRS-9939A/1986-...l-Iac-Adjuster
tjm73 is offline
post #6 of 11 Old 05-18-2017, 01:31 PM
Surging is caused by 2 things. Vacuum leaks and wrong injector flow rate. Check for leaks with a smoke test. Check fuel pressure. 39-40 with vacuum off.
Idle plate might help by raising idle to mask the real problem. Don't touch the throttle screw to raise the idle, you will only cause more headaches.
The hole in the throttle plate is a trick to allow more air into the engine to stop it from stalling when coming to a stop.
Start with vacuum leaks. Definitely use a smoke test.
TomR likes this.
kjb302ho is offline
post #7 of 11 Old 05-18-2017, 01:32 PM
What throttle body are you using? All throttle bodies are not the same...
kjb302ho is offline
post #8 of 11 Old 05-18-2017, 03:40 PM
indy2000's Avatar
if the air a tb flows is not the same as programmed in the ecm
surging can happen
TomR likes this.
indy2000 is offline
post #9 of 11 Old 05-18-2017, 06:31 PM
You need to tune the bloody thing properly.
TomR likes this.
Bossxr8 is offline
post #10 of 11 Old 05-18-2017, 06:36 PM
What he said.
TomR likes this.
post #11 of 11 Old 05-18-2017, 07:27 PM
TomR's Avatar
Your tune or TB is set up wrong or you have a vacuum leak. Don't drill holes. Drilling a hole is no different than resetting the throttle closed stop except you can't adjust it or undo it. It's dumb advice.
Paulie likes this.
89 LX. 363, single turbo S482 FMW, Super Vic EFI, Fox Lake Stage III heads, solid roller, glide. Holley HP EFI. (combo varies)
TomR is offline
