347 Stroker Clearance Question - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 5 Old 05-17-2017, 04:30 PM Thread Starter
I am building a 347. Bottom end has been built and I used Wiseco Pistons that are -7cc with valve reliefs. I have installed a TFS stage 2 cam. My question is, will I have any piston to valve clearance issues? I will be going with either performer RPM or Blueprint heads. Thank you in advance.
cjkcue1986 is offline
post #2 of 5 Old 05-17-2017, 08:13 PM
Highly unlikely, but make sure to check
630-462-3978 Shop Direct
877-723-5487 Shop Toll-Free
TONS of Build Photos Ck at
Make sure to sign up for
strokeme is offline
post #3 of 5 Old 05-17-2017, 09:30 PM Thread Starter
Thank you very much. I will be checking the clearance but didn't want to waste my time if it was an obvious clearance issue.
post #4 of 5 Old 05-19-2017, 03:31 AM
Mark O'Neal's Avatar
You'll probably end up with about .280.
But we still have to check.
Mark O'Neal is offline
post #5 of 5 Old 05-19-2017, 03:11 PM Thread Starter
Thank you!
