1,2,3 piece pushrods...Where do I begin? - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 24 Old 05-17-2017, 04:17 PM Thread Starter
My new valve springs features open spring pressures of 448 lbs.
Cam lift is .577
I probably won't take the 347 over 6200 RPM.
Pushrod diameter needs to be 5/16" and 6.450" long overall length.
I'm looking to reduce any pushrod deflection and have good ball to cup fitment.
I'm looking for a little schooling before contacting a supplier.
'95 Mustang GT
CPR 347
fasterthangas is offline
post #2 of 24 Old 05-17-2017, 04:59 PM
Saleen414's Avatar
Why does the pushrod have to be 5/16" ?
26 X 8.5 Hoosier
Best 1/4 mile time 8.623 @ 159.82 mph with a 1.34 60' (5.55 1/8th at 128)
Best 1/8 mile time 5.384 @ 130.75 mph with a 1.29 60'
2001 V-6 5 speed Mustang 189k miles and counting
08' Bullitt #4097 N/A 325 RWHP <<<<<FOR SALE!
Saleen414 is online now
post #3 of 24 Old 05-17-2017, 05:03 PM Thread Starter
Guide plate limitations as well as rocker body interference, not to mention possibly having to open up pushrod holes in heads. Heads are already installed.
'95 Mustang GT
CPR 347
post #4 of 24 Old 05-17-2017, 05:16 PM
Saleen414's Avatar
They make pushrods that have 3/8" body that neck down to 5/16" at both ends so rocker arm clearance is not an issue. I seriously doubt that the hole in the head has to be opened up at all, unless you are running the old school cast iron heads that had slots instead of round holes for the pushrods. Guide plates for the 3/8" pushrod are easy to get.
26 X 8.5 Hoosier
post #5 of 24 Old 05-17-2017, 05:19 PM
Saleen414's Avatar
These guys can make anything you want.
Smith Bros. Pushrods | Redmond Oregon
26 X 8.5 Hoosier
post #6 of 24 Old 05-17-2017, 05:21 PM Thread Starter
Thanks. I hadn't thought of that.
'95 Mustang GT
CPR 347
post #7 of 24 Old 05-17-2017, 05:22 PM Thread Starter
Manton, Trend, Smith Bros??? 1,2, or 3 piece? Pros? Cons?
'95 Mustang GT
CPR 347
post #8 of 24 Old 05-17-2017, 05:24 PM Thread Starter
Hah! You read my mind.
'95 Mustang GT
CPR 347
post #9 of 24 Old 05-17-2017, 06:42 PM
The one's that I have always have the best luck with come from FTI. Don't know who his vender is. But the always work pretty damn good. He saves me from the guessing game with his recommendations. Another thing that is kinda funny is they always run quite after I switch over from the sets I always have on hand from the catalog Comps .080 walls that I have collected. Where he gets his I don't have a clue. I always run the 210* ball.
2 step is offline
post #10 of 24 Old 05-17-2017, 06:55 PM
afr head?
630-462-3978 Shop Direct
877-723-5487 Shop Toll-Free
TONS of Build Photos Ck at
Make sure to sign up for
strokeme is offline
post #11 of 24 Old 05-17-2017, 07:26 PM Thread Starter
Originally Posted by strokeme View Post
afr head?
Yes. 185 Renegade.
post #12 of 24 Old 05-17-2017, 07:31 PM
Always have had good luck with trickflow...
https://www.summitracing.com/search/...omoly-pushrods
bender4601 is offline
post #13 of 24 Old 05-17-2017, 08:09 PM
Originally Posted by fasterthangas View Post
Yes. 185 Renegade.
Look at where the guideplate notch is in relation to the pushrod hole in the head and you will see why afr is anti 3/8 pushrod in the ford heads. Trend makes the trick flow and many of comp cams pushrods. If you stay with a 5/16 you can just use a .105-.120 wall. Get a 1 piece swedged end pushrod regardless. You dont need anything dramatic either.
strokeme is offline
post #14 of 24 Old 05-18-2017, 02:05 AM
rob
rob's Avatar
I have a low mile set of trickflow 5/16" 6.450" for $55. I have no use for them anymore.
1982 Ford Fairmont Futura H/C/I, fuel injected and turbocharged 10.67@128
rob is offline
post #15 of 24 Old 05-18-2017, 09:50 AM
Old timer
Ed Curtis's Avatar
I've put 3/8" push rods in "out of the box" AFR heads but it's not done with catalog parts.
"Haters gonna hate 'cause they just can't replicate."
Ed Curtis is offline
post #16 of 24 Old 05-18-2017, 09:59 AM
SRTthis798's Avatar
Trader Feedback: (15)
we had to open the heads up on the highports to fit a 3/8" push rod.
DT Racing and Fabrication
Crew Chief
HOME OF THE FASTEST X LEGAL SVA 302!
my car-88lx...time to go nucking futs with it!
SRTthis798 is offline
post #17 of 24 Old 05-18-2017, 11:35 AM Thread Starter
Thanks for the help guys. I ordered a one piece pushrod set from Smith Bros. I had used them in the past with good results.
post #18 of 24 Old 05-18-2017, 12:39 PM
absolutely, but the at home guys, well ya
strokeme is offline
post #19 of 24 Old 05-18-2017, 12:41 PM
depends heavily on the rocker or shaft used. pushrod is typically centered in the hole but may be pushed towards to valve cover rail, jesel is good for this
strokeme is offline
post #20 of 24 Old 05-18-2017, 12:56 PM
SRTthis798's Avatar
i'll give you 1 guess what we run LOL
Crew Chief
post #21 of 24 Old 05-18-2017, 01:21 PM
strokeme is offline
post #22 of 24 Old 05-18-2017, 01:30 PM
SRTthis798's Avatar
but at this point with that motor... whats opening up a few push rod holes LOL
Crew Chief
post #23 of 24 Old 05-18-2017, 01:51 PM
Old timer
Ed Curtis's Avatar
A "B-Cam" and some Proform rockers?
post #24 of 24 Old 05-18-2017, 02:55 PM
SRTthis798's Avatar
welp... we wont have that 8.2 record for much longer... thanks ed!
Crew Chief
