Exhaust 2.5" or 3" - Ford Mustang Forums : Corral.net Mustang Forum
 6Likes
  • 2 Post By 6sally6
  • 1 Post By 1995gtCPE
  • 1 Post By strtcar
  • 1 Post By tmoss
post #1 of 30 Old 05-16-2017, 11:00 PM Thread Starter
Exhaust 2.5" or 3"
I bought a car recently that has a 331 that was dyno'd at 349hp/352 ft-lbs to the wheels. Getting under the car last night I found the Flowmasters welded into the OEM pipes from the midpipe back. The rest of the exhaust is BBK 1 5/8" long tubes and a 2.5" BBK H-pipe.
I will be replacing the cobbed together restrictive cat-back with a mandrel bend cat-back. I can go with a 2.5" or 3" setup.
At what point does experience tell us that that 1 3/4" long tubes and 3" exhaust are the right thing to do? If I redo my exhaust in a year or two I will go with 1 3/4" to 3" if it would benefit the car. If that is the case I will run the 3" cat-back now. Otherwise I will run a 2.5" cat-back
tjm73 is offline
post #2 of 30 Old 05-17-2017, 12:35 AM
2.5 is plenty big enough.
6sally6
JPX and Caprimaniac like this.
6sally6 is offline
post #3 of 30 Old 05-17-2017, 08:33 AM
1995gtCPE's Avatar
Trader Feedback: (34)
Corral will say smaller is better. Better do 2in!
sradtodrag likes this.
80 coupe, A4 347, Bullet hyd roller, ported 11r 190's, ported Super Vic, HPI e85 carb, Liberty TKO500/4.30
1995gtCPE is offline
post #4 of 30 Old 05-17-2017, 09:40 AM
BK_5.0's Avatar
As a rule of thumb I think a 2.5 inch dual exhaust setup is good till about 500hp(at the motor) before it starts to become a restriction. Take it for what it is worth... In my opinion it comes down to money, if your current stuff isn't all crusty and rusty keep it and be happy with the 2.5in setup. Otherwise take the opportunity to put the big 3inch setup on and don't look back.
BK_5.0 is offline
post #5 of 30 Old 05-17-2017, 09:50 AM Thread Starter
Car has AFR 185 heads, an Anderson N61 cam and Trickflow R-series intake. Backed by a T5 now but will get upgraded to a TKO with 4.10's eventually.
tjm73 is offline
post #6 of 30 Old 05-17-2017, 12:39 PM
1995gtCPE's Avatar
So 2.5 is not a restriction under 500hp?
post #7 of 30 Old 05-17-2017, 02:47 PM
I had the same decision with my 331 with 1 3/4 long tubes and went ahead and built a 3 inch system with a x pipe and race bullets and I am very happy with it
1988 Mustang GT "Way too loud to be this slow"
2017 California Special - Wife's Hot Rod
Bigcam88 is offline
post #8 of 30 Old 05-17-2017, 03:04 PM
Saleen414's Avatar
The 14' GT500 made 662 HP with cast iron exhaust manifolds and 2.5" exhaust.....
26 X 8.5 Hoosier
Best 1/4 mile time 8.623 @ 159.82 mph with a 1.34 60' (5.55 1/8th at 128)
Best 1/8 mile time 5.384 @ 130.75 mph with a 1.29 60'
2001 V-6 5 speed Mustang 189k miles and counting
08' Bullitt #4097 N/A 325 RWHP <<<<<FOR SALE!
Saleen414 is online now
post #9 of 30 Old 05-17-2017, 03:25 PM
1995gtCPE's Avatar
Congrats.
post #10 of 30 Old 05-17-2017, 03:37 PM
and the 2.5" exhaust hurt performance a bunch, on a quick glance MM&FF picked up 38 rwhp with just a 3" catback
Bigcam88 is offline
post #11 of 30 Old 05-17-2017, 03:43 PM
it's not going to hurt power by going with 3" you just may not gain much, the big thing it it will be a little heavier and if doing tail pipes a tighter fit
Bigcam88 is offline
post #12 of 30 Old 05-17-2017, 03:52 PM
Cougar5.O's Avatar
Search?
3" exhaust or not
2.5 or 3" exhaust for 351w
Notice the video posted in both links showing a gain of 14HP on a 600+ HP motor (2 1/2" to 3") using an exaggerated 20' truck-sized exhaust system.
Notice a certain poster trolls in every thread, doesn't give a hoot if the guy will spend $1000+ for 3-4 HP. Don't be a sucker for internet machismo.
'87 20th Anniversary Cougar - 427W coming soon -
Cougar 7.0?
2012 GT500
Cougar5.O is offline
post #13 of 30 Old 05-17-2017, 04:44 PM
Hotrod just did a back to back dyno comparison, 3" was better everywhere
TomR likes this.
strtcar is online now
post #14 of 30 Old 05-17-2017, 04:46 PM Thread Starter
I tried searching. Got mixed results.
tjm73 is offline
post #15 of 30 Old 05-17-2017, 04:50 PM
Saleen414's Avatar
The 3" will be louder. I doubt that at 350ish rwhp that you could tell the difference between a 3" and a good 2.5" exhaust, except for the noise and the lighter wallet.
26 X 8.5 Hoosier
post #16 of 30 Old 05-17-2017, 05:30 PM
Cougar5.O's Avatar
This is a less abrasive version of my post.
I agree.
Cougar 7.0?
2012 GT500
post #17 of 30 Old 05-17-2017, 05:30 PM
TomR's Avatar
You are probably good at 2.5 inches with duals if the pipe isn't all kinked up. While it will be a tiny bit better bigger, the weight and cost will go up. The power return on the investment at your power level would never pay you back, especially since it would add weight.
Don't think for a second the pipes will suddenly just choke off at a certain power level and be perfectly fine below that level. It is a gradual back pressure increase with more power.
I can watch this on my data log. My downpipe pressure into dual 3" and dual Borla Pro XS was about 1-2 lbs at 800 HP. At 1200-1300 HP it is about 2-3 psi. It doesn't suddenly skyrocket.
89 LX. 363, single turbo S482 FMW, Super Vic EFI, Fox Lake Stage III heads, solid roller, glide. Holley HP EFI. (combo varies)
TomR is offline
post #18 of 30 Old 05-17-2017, 06:54 PM
1995gtCPE's Avatar
Shortcut here, shortcut there.... Next post, "hey Corral why is my combo down on power?..." Get what you can afford. If 2.5 is what you can swing, then get it and not worry about it. Like the old saying goes, "Buy once, cry once". Everyone has different ideas of what they want and im good with that. I want the most HP for my dollar. I bought what i could afford and thats that. Some want good MPG, some want a quiet v8, some want a 427 stroked windsor to make 500hp cause anything smaller than that is not streetable. Folks post here asking for opinions. Theres mine.
Rock4451 likes this.
post #19 of 30 Old 05-17-2017, 07:45 PM Thread Starter
I am going to change my cat-back. I had MAC exhaust years ago and I plan to run it again. 2.5" v. 3" is a $45 difference.
tjm73 is offline
post #20 of 30 Old 05-18-2017, 12:23 AM
Do a comparison of the 2 (its only a $45 difference!)and let us know if you can FEEL the diff!
I think I know the answer.........
6sally6
6sally6 is offline
post #21 of 30 Old 05-18-2017, 02:30 AM
Rock4451's Avatar
1995 has it right...if you're buying new, you spend as much money to go slower if you buy parts meant to flow less air.
86 Mustang 302 N/A
350rwhp/341rwtq
Rock4451 is offline
post #22 of 30 Old 05-18-2017, 08:17 AM
1995gtCPE's Avatar
6sally6
OP, there you go. The above post insinuates that you will not be able to feel a power difference with 3.0 vs 2.5, AND you will save $45! Never mind that your heads, cam, intake stroker is making 302 power. You dont need the extra bit of power cause you will never FEEL it!
Seriously, get what aligns with your goals and finances.
post #23 of 30 Old 05-18-2017, 09:46 AM
Old timer
Ed Curtis's Avatar
Truth spoken here....
....if the OP will listen to this advice is a whole other topic...
"Haters gonna hate 'cause they just can't replicate."
Ed Curtis is offline
post #24 of 30 Old 05-18-2017, 11:12 AM
tmoss's Avatar
Trader Feedback: (47)
would the 5.8L have made more with a larger exhaust? My 2010 5.4L made 673 to the tire with cast iron and 3" system.
Tom Moss
tmoss is offline
post #25 of 30 Old 05-18-2017, 11:34 AM
Saleen414's Avatar
Yes it probably would. I was just stating that as delivered in stock form it cranked out 662 hp with cast iron manifolds and 2.5 exhaust. I never insinuated it could not be improved upon. It just was not a huge issue at that power level as far as Ford was concerned. I am sure NVH, emissions and other factors went into it as well. If the end goal of the engine was around 700 HP and above, then maybe the exhaust system would have been different.
26 X 8.5 Hoosier
post #26 of 30 Old 05-18-2017, 12:13 PM Thread Starter
For $45 bucks I am going with the 3" cat-back. In a year or so I will complete the change/upgrade by going to 1 3/4 long tube headers and a 3" mid-pipe.
My current exhaust will get the job done, as it does now, but I want to change it. There isn't a ton to do mechanically for more power in the combo short of a custom cam and perhaps I will do that in a couple years. For now the once chrome headers look like a steaming pile of poo and the H-pipe is crusty. So I do the cat-back now and the mid-pipe next year and the headers (ceramic) after that. Don't have to do it all at once.
tjm73 is offline
post #27 of 30 Old 05-19-2017, 11:33 AM
the main pieces of the puzzle in exhaust sizing needs are inlet flow capability and valve events. HP is not a design criteria except in magazines.
If the motor responds successfully with higher ratio exh rockers or with higher flowing and larger cross-section headers and exhaust system, then the motor combination needs more exhaust activity in the valve events.
If the motor responds successfully with lower ratio exh rockers or with lower flowing and smaller cross-section headers and exhaust system, then the motor combination needs less exhaust activity in the valve events.
In either of the scenarios HP vs exhaust exh size is not a player. The engine's air movement and valve events (that time the air movement to piston position/crank rotation) are the players.
I dont care if your supercharged motor does make 1000 hp on 2" exhaust system with 15psi, or your old carbed 289 ford makes 475 hp on a 3 1/2" exhaust system and ported early heads. Its not relavent. the combination defines the need.
Your better assumption would be to say:
If I have xxxxx inlet capability, then I need between 60% and 80% on the exhaust side (if naturally aspirated). This is not the head flow. this is the total flow seat to muffler outlet (or collector)
buddy rawls is offline
post #28 of 30 Old 05-19-2017, 11:59 AM
Cougar5.O's Avatar
Now that your goals are clearer, there's no reason not to replace the cat back with a 3" version.
As far as the H-pipe and headers, buddy is correct in that it's not a simple formula. There are a few great threads about headers on a couple of the more technical forums out there that better flush out what buddy is raising, though at your power level you're talking about minimal torque curve shifts that may or may not be noticable or measurable. "It depends"
post #29 of 30 Old 05-19-2017, 12:45 PM Thread Starter
Any suggestion on how one might accurately estimate the inlet capability of any given setup? Assuming you know the cam specs.
tjm73 is offline
post #30 of 30 Old 05-19-2017, 03:58 PM
tmoss's Avatar
PipeMax is a good program good sizing your whole inlet and outlet system. It's cheap as those kinds of programs go and has been developed over many years by Larry Meaux - look him up on Google. It will size your headers, X or H pipe, tell you lengths for various pieces of the system and recommend a total length for the whole system. I bought it years ago for $25, not sure what it is today.
cbydesign likes this.
Tom Moss
tmoss is offline
