Does it hurt to have too much fuel pump? - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 4 Old 03-20-2017, 10:41 AM Thread Starter
FlamedHatch's Avatar
Got a good deal on a 255 pump and im probably going to make 315-325 rwhp
POS 91 LX 5.0
308 DART PRO1'S
TREMEC 3.73
FlamedHatch is offline
post #2 of 4 Old 03-20-2017, 11:13 AM
I don't believe so with a return style system. Anything not used is just returned to the tank to be pumped again.
tjm73 is online now
post #3 of 4 Old 03-20-2017, 11:26 AM
For that power level, you will be fine. There is a chance with even larger pumps of fuel overheating as the small fuel line sizes on foxes (especially the return line) cause the pump to work harder and create added heat that continues to be circulated through the system. Even on those, the risk is pretty low unless you frequently run the tank near empty.
cntrain is offline
post #4 of 4 Old 03-20-2017, 06:38 PM
TaraFirma's Avatar
The answer to your question is: Yes.
However with the setup you are going to run, you won't have a problem.
To fly is Heavenly, to hover is divine.
Don't let your mouth write a check your a$$ can't cash.
TaraFirma is offline
