225 high ports too much for my applications - Ford Mustang Forums : Corral.net Mustang Forum
 1Likes
  • 1 Post By buddy rawls
post #1 of 11 Old 03-19-2017, 06:17 PM Thread Starter
I have a stock 302 shortblock and eventually plan on a 363-418" engine. I really only want to buy one set of heads and was wondering if 225 high ports could be made to work with a 302 with a custom cam. Car will be carbed with a stick. It will be street driven with weekly trips to the street legal drags on Friday nights. I've also looked at the 205 11r's but is the exhaust port going to be a limiting factor when you upgrade to a bigger engine displacement?
Carbed79 is offline
post #2 of 11 Old 03-19-2017, 06:28 PM
Trader Feedback: (53)
As long as you get the custom cam designed for the combo, they will work..
1. Woman
2. Dyno
3. Dragstrip
sradtodrag is offline
post #3 of 11 Old 03-19-2017, 06:33 PM
You may have trouble with the valve size on a 225 head fitting a stock 302 shortblock. If these are just temp heads there are plenty of TFS 170 heads for < $1k that you can sell after using.
strtcar is offline
post #4 of 11 Old 03-19-2017, 06:49 PM Thread Starter
I was wondering the same thing about the valves and piston reliefs. Hopefully with a custom cam they can take the duration and valve size into account. I could also enlarge the valve reliefs i needed to. But I would prefer not too.
Carbed79 is offline
post #5 of 11 Old 03-20-2017, 09:45 AM
nastynotchback1's Avatar
I'm not gonna say it has not been done before.I did it with a set of 225 Canfields and the right cam and it worked out well but more than likely you need to set them to the side right now and find some cheap 165 or 170 heads until you build the big motor.
81 coupe S/W#7(SOLD
90 hatchback S/S#20
94 WHITE LIGHTNING
nastynotchback1 is offline
post #6 of 11 Old 03-20-2017, 10:21 AM
run the stock cam, installed around 109 ICL, and 1 3/4 headers (minimum) or 1 7/8 headers to a 3" exh system (minimum)
tmoss likes this.
buddy rawls is offline
post #7 of 11 Old 03-20-2017, 12:45 PM
Well there is your answer. Let us know how it runs.
81 coupe S/W#7(SOLD
90 hatchback S/S#20
94 WHITE LIGHTNING
post #8 of 11 Old 03-20-2017, 02:28 PM
SRTthis798's Avatar
Trader Feedback: (15)
i looked at it since i have a bad ass set of 225 highports i got off the X car...
i ended up just starting a windsor build to put them on
DT Racing and Fabrication
Crew Chief
HOME OF THE FASTEST X LEGAL SVA 302!
my car-88lx...time to go nucking futs with it!
SRTthis798 is offline
post #9 of 11 Old 03-20-2017, 06:28 PM Thread Starter
Would a victor carbureted manifold be a good match for 225 high port and 1 7/8" headers leading to 3 to 3 1/2" exhaust? What size carb would be needed with this combo? Thank you for all the replies. I will report the results. I'm planning about a year for the car to be completed.
Carbed79 is offline
post #10 of 11 Old 03-20-2017, 11:43 PM
Still talking for the stock 302 shortblock?!? If running the stock cam degreed per the above, just slap a used Vic Jr on with a 650 mech sec carb. You'll have to find a suitable spring/ retainer setup for the interim rig also.
funnelcake is offline
post #11 of 11 Old 03-21-2017, 12:11 AM Thread Starter
Yes still talking 302 shortblock.
Carbed79 is offline
