Loud solid roller - Ford Mustang Forums : Corral.net Mustang Forum
 1Likes
  • 1 Post By 10SECFox
post #1 of 7 Old 03-19-2017, 02:44 PM Thread Starter
92Calypso347's Avatar
Loud solid roller
Help guys!! Did a solid roller setup and it's way louder then any other I've been around, other then lash what could make it so noisy?
347 11.1 compression, ported AFR 165 heads, custom Woody cam, Vic Jr intake with a 750 carb, c4 Trans 3800 stall and 4.10s on a 28" DR tires, 1.75 long tubes and spin tec mufflers, Car ran 11.38 @119 with a 1.5 60's on motor also have a NX plate jetted for 150
92Calypso347 is offline
post #2 of 7 Old 03-19-2017, 04:48 PM
Moderator
Jeff88coupe's Avatar
You double check your valve lash? Sure oil it making it to the valve tips and lifters well?
Xtreme 8.5" -Heads up 1/8th mile limited 8.5 class at Kilkare Dragway
Dedpedal Racing;Sponsered by
;Tuned by
Boss block Big bore 347/225 TFS HP's/SR/BW S476R/A2W/PG/FAST xfi on E85
5.33 at 134.9 on 26x8.5 in 1/8th @3380#
Jeff88coupe is offline
post #3 of 7 Old 03-19-2017, 11:20 PM
Sometimes if you set lash cold, and it's supposed to be set "hot", they'll be noisier than usual. As the engine warms up, lash increases, on mine roughly .009". So I have to set the cold lash .009 tight and when it's up to temp, it checks perfect.
toddturbo is offline
post #4 of 7 Old 03-20-2017, 06:10 PM Thread Starter
My cam card said .16 on intake and exhaust
post #5 of 7 Old 03-20-2017, 06:43 PM
what lifters? .016 is hot, so set it .006 tighter and check when hot
strokeme is offline
post #6 of 7 Old 03-23-2017, 05:38 PM
10SECFox's Avatar
If you set it at .16 like you stated above that is your problem. I'm sure the cam card states .016
TomR likes this.
'91 Hatch - 358W 10.5:1 -TW170's - Lunati Solid Flat cam (61041) 241/249@.050 .554/.576- Weiand Stealth intake- Holley 800DP- C4 w/4000 stall -8.8 rear with 4.30 full spool w/31spline eliminators - M/T 28/10.5/15W slicks. 7.12@95.5mph 1.58 60' so far.
10SECFox is online now
post #7 of 7 Old Yesterday, 05:15 PM
TomR's Avatar
I had loud solid roller on a motor and it was the Harland Sharp shaft rockers. They had the geometry 20 degrees or more off on the adjusters. It would also eat up push rod tips.
They redid the rockers and that cured it.
So you need to check everything, even geometry between the PR and the rocker.
89 LX. 363, single turbo S482 FMW, Super Vic EFI, Fox Lake Stage III heads, solid roller, glide. Holley HP EFI. (varies)
TomR is offline
