I am planning on just getting rid of the pcv system. I don't want to be blowing oil into my intake trying to keep a closed system. I am blowing some oil out the rear main seal I want it to breath as much as possible
I run two lines, one ID 5/8" from the PCV, one ID 3/8" from the valve cover filler neck, both into Moroso PN 85473. No lines into the intake manifold, no possible way for oil to get into the intake. 5/8" & 3/8" provide plenty of ventilation for an NA small block.
I made my catch can for around $30 in parts and I drain it every 1000 miles or so, and have had no more oil seeping past grommets, and the oil that goes into the engine, if any, is significantly reduced.
Related Threads
Ford Mustang Forums
9.8M posts
200.6K members
Since 2001
