i had this posted on the general tech forums but have only had 1 response. i am going to install the Mcleod hydraulic throw out bearing conversion , but have a less than 4000 mile centerforce setup in my car. which will not work with the HTOB conversion . does anybody have experience with removing weights? Mcleod direction say to remove weights. kinda worried about slippage, i did some google searching and it seems like a pretty common deal to remove weights for different reasons. i was hoping not to have to pull my headers for bell housing removal to change to a different preasure plate. my setup is a 347 should be upper 475 horse by the math, but car has not seen a dyno. Any input would be great . Thanks
