difference between siamese and non siamese bore blocks - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 6 Old 12-10-2002, 01:12 AM Thread Starter
F. Castle's Avatar
Question difference between siamese and non siamese bore blocks
i already asked once but noone seems to know. what are the pros and cons of a siamese bore block over a non siamese bore? the block i was lookin at is the N351 motorsport block. it is a wet or dry sump, 9.5" deck height, 4 bolt main block. My plans are to punch it out to 393-410 c.i., run 8-1 compression and put up to 20 pounds of boost through it via an F-1 blower. So what would be the benefit of spending the extra money for a siamese block, is it necessary, or am i good with my original choice. any input will be appreciated, thanx
F. CASTLE
STR8HEAT
MOTORSPORTS
'90 Notch in the works...
F. Castle is offline
post #2 of 6 Old 12-10-2002, 01:34 AM
cosmoracer's Avatar
A siamese bore block means that there are no coolant passages between the cylinders. These blocks tend to have thicker walls, therefore a capacity for a larger overbore. They do TEND to have more cooling issues however.
Cream may rise to the top, but sometimes sh&t floats too.
cosmoracer is offline
post #3 of 6 Old 12-10-2002, 01:50 AM Thread Starter
F. Castle's Avatar
is that all?
thanx man you proved me right. anyone else. so since i plan on "trying" to drive my car on the street, i should stick with my original choice right. N-351. thanx,
F.CASTLE
STR8HEAT
MOTORSPORTS
post #4 of 6 Old 12-10-2002, 01:56 AM
A siamese bore block tends to be stronger than a non siamese bore block. There are NO cooling issues with a siamese bore block with a good cooling system i.e. aluminum radiator, good fan, good water pump. Mine runs 185 degrees in all conditions.
D-2R ProCharged R302 331, 1.393 60 ft, 5.868 @ 123.119, 8.953 @ 155.80, 3400 lbs (with me), MM&FF Feature June 2003
John91coupe is offline
post #5 of 6 Old 12-10-2002, 02:01 AM
cosmoracer's Avatar
John, that's why I put tend in bold, my car actually ran cooler after the R block switch. If I said there was no problem, somebody will come on here and jump my sh*t for that. If you are having issues with a production block, you will have more issues with a siamese block.
post #6 of 6 Old 12-10-2002, 11:08 AM
Gotcha, thanks for the clarification and I know exactly what you mean and agree 100%.
John
