N/A 306 Dyno #'s - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 26 Old 11-16-2002, 07:24 AM Thread Starter
N/A 306 Dyno #'s
Just got the car dynoed today....
317RWHP 335RWT
Mods:
9.4:1 306, TFS TW heads, Custom Cam from Panhandle Performance, Holley Sytemax Intake, 75 mm Mass Air, 70mm t/b, 30lb injectors, BBK Long Tubes, X pipe, 2 Chamber Flows.
What do you guys think about these #'s for a N/A 306?
Typical bowtie eater!
lpmorgan is offline
post #2 of 26 Old 11-16-2002, 07:31 AM Thread Starter
Oh yea. Timing at 16 Degrees and F/P at 37lb's (vac off)
lpmorgan is offline
post #3 of 26 Old 11-16-2002, 08:08 AM
11Sec_Lx's Avatar
Very nice, now get some track numbers!!!
11Sec_Lx is offline
post #4 of 26 Old 11-16-2002, 09:32 AM
Hey dude I think that not bad numbers! I have just about the same set up on my notch. Mine is 308ci with 80mm mass air meter 30# injectors. I was hoping that I could get around 325 hp. With my notch weighting 2750 lbs I’m hoping that I will have some good track #
Darryl
Wild Thing is offline
post #5 of 26 Old 11-16-2002, 11:57 AM
Very nice. Did you adjust the timing any, if so how did the hp numbers compare? Just curious, because Im running tw heads and everyone is saying 16-18 timing.
89 coupe: tw heads (ported), cobra intake (lower ported, upper port matched), f cam,...
twistedcoupe is offline
post #6 of 26 Old 11-16-2002, 02:24 PM Thread Starter
As far as track #'s... they suck because I have to let out of second three times, the thing will not stop spinning!!!!!!! It's a conv, so the weight distribution is even worse. I ran a best of 13.6 @ 105 with a 2.3 60 foot. Since then though I've added sub frames so it might help. I'm pretty sure with slicks it's got 12.7's in it. In jan I'm getting some 17's with drag radials, then we'll see what she'll do!
As far as the timing, I started at 16 and ran out of dyno time to try and take it any higher. I don't think going 17 or 18 would make that much diff though, and wouldn't be worth the chance of pinging the motor.
Thanks for the replys!!!!!!!
lpmorgan is offline
post #7 of 26 Old 11-16-2002, 03:30 PM
Location: Slinger, Wis. , home of worlds fastest 1/4 mile oval
Outstanding numbers! What RPM did you make peak hp and tq at? Mine made 288@5100 and 322@3800 with my GT40 setup...congrats.
91 Twilight blue LX hatch, worked GT40 irons, GT40 intake w/home ported lower, Crane 2031, 24 lb inj.,FMS 1.72s, FMS ceramic shorties, Bassani X, Super Turbos, 3.73s, C&L 73mm, MAC air intake, MAC 70mm TB, FMS wires, DynaBatt, chrome Hurst w/Flameball, Granatelli adj lowers, Steeda front /Eibach drag rears, Mach 1 hood w/ pins, Nitto DRs, FMS driveshaft, T5Z, FMS AC delete,smog delete
Best ET: 12.76@108.16
1.90
288rwhp@5100
322rwtq@3800
94 Tbird 4.6
3.27 tractionlok
2001 Suzuki Bandit 1200
LX Pony is offline
post #8 of 26 Old 11-16-2002, 05:18 PM
Grn92LX's Avatar
Trader Feedback: (21)
Nice #'s. Can you post the graph? 18* timing is where TFS TW heads seem to like timing. My car does not ping and it didnt ping when I tried 20* either. My advice is to make some passes on 16*, then bump it to 18* and see what happens.
92 Mustang LX 347 11:1
TEA 205cc Twisted Wedge, FTI cam, Ported Victor 5.0, 5 lug disc conversion, ROH ZS wheels, Anderson PMS, 4.30
Grn92LX is offline
post #9 of 26 Old 11-16-2002, 05:41 PM
ksstang's Avatar
Paul-- I am still very please with what the car did yestday! I have been giving it alot of thought today, and looking around, I am still going to stick with some Trick Flows, and a Holley, leave my cam in it, and see what happens
Kyle
Kyle
1993 LX Coupe
1989 GT (Project Car)
I Understand The Jeep Thing..Thats Why I Drive A Z-71
ksstang is offline
post #10 of 26 Old 11-17-2002, 08:43 PM Thread Starter
The motor likes to rev, it made peak HP at 5600 and peak torque at 4500 so my guess is that this thing would be best shifted at around 6500-6800 at the track, but need a rpm extender first.
I do regret not bumping the timing to 18 and seeing what it would have done. I will be adding an ignition box and distributor soon, so I'll go back to the dyno in hopes of around 325RWHP with those plus 18 degrees, we'll see!
Thanks for the replys, it's nice to hear my combo worked out for the best!
lpmorgan is offline
post #11 of 26 Old 11-17-2002, 09:46 PM
No need for an extender with what you have. There is NO reason to be shifting that thing any higher than about 6100, and thats just the 1-2, your 2-3 and 3-4 shifts should be at around 5900 for the best times. You need more cam to be able to shift it higher than that, and probably should have more to utilize that intake.
99 black cobra built bottom end, ported NAVI heads, cams, etc. n/a w/n20
93 white coupe- 306ci, 14psi s-trim, tko600
'06 black Subaru STI- spec clutch, blizzak snow tires, 475hp on 91 octane.
N2O88 is offline
post #12 of 26 Old 11-17-2002, 10:51 PM
Not bad at all!
Be careful, these heads are good about not pinging but seem to like less advance up top.
JoeDirte is offline
post #13 of 26 Old 11-18-2002, 06:34 AM
pkstang's Avatar
Trader Feedback: (161)
can you post the graph
pkstang is offline
post #14 of 26 Old 11-21-2002, 02:40 PM
Grn92LX's Avatar
Exclamation
So, can we see the graph?
Grn92LX is offline
post #15 of 26 Old 11-25-2002, 07:24 AM Thread Starter
I've tried to post the graph but I can not figure out how to put a pic on this website. So either tell me how to, or post your email and I'll send it to you. Either way I'd be happy so show you!
lpmorgan is offline
post #16 of 26 Old 11-25-2002, 10:36 AM
SN95LEEN's Avatar
email the graph to me, I'll post it...
sleepyboy18@yahoo.com
...thanks.
Originally posted by Anaconda
"...your sig sucks..."
SN95LEEN is offline
post #17 of 26 Old 11-26-2002, 03:02 AM
SN95LEEN's Avatar
Here's the graph and data sheet guys...
SN95LEEN is offline
post #18 of 26 Old 11-26-2002, 05:30 AM
90trunk's Avatar
Thumbs up
Nice graph. The torque really stayed above 300, didn't it?
Regards,
Craig
12.79@103.24 at Milan,3450#...
Dynojet'd 286rwhp/331rwtq Stock Cam, GT40 Irons
90trunk is offline
post #19 of 26 Old 11-26-2002, 09:42 AM Thread Starter
Now that the graph is posted ( thanks 95snleen!) do you guys have any comments or suggestions?
How more power do you think it will make once I get a new MSD distributor and a 6AL Ignition Box?
What kind of times do you guys think the heavy 87 GT Conv is capable of running if everythin were to fall into place ie: traction, good driving ect....?
lpmorgan is offline
post #20 of 26 Old 11-26-2002, 02:22 PM
Well ASSuming you are about 200lbs, and the car is full weight, making raceweight about 3550, you should be able to see a trap speed around 108-109. The time you get all depends on traction, but optimumly you can put up a 12.20-12.30 with that trap. DId you try 18-20 initial timing? What are your cam specs?
N2O88 is offline
post #21 of 26 Old 11-26-2002, 05:58 PM
pkstang's Avatar
Thumbs up nice numbers
-try running more timing (18)
-what are the specs on that cam
pkstang is offline
post #22 of 26 Old 11-26-2002, 09:10 PM Thread Starter
Cam Specs....
Lift .536Int / .536Exh
Dur 276Int / 279Exh
Dur @ .050 224Int / 226Exh
Lobe Sep 110
I really kick myself for not trying more Timing while at the Dyno, but from what I've heard on other combos I thought 16 was pretty high. I guess these TFS TW's like 18 degrees though.
lpmorgan is offline
post #23 of 26 Old 11-26-2002, 11:38 PM
wrathchild's Avatar
Is that a custom cam or off the shelf?
wrathchild is offline
post #24 of 26 Old 11-27-2002, 12:47 AM
SN95LEEN's Avatar
Here ya go
317RWHP 335RWT
Mods:
BTW, who is it that grinds the custom cams at Panhandle Performance?
SN95LEEN is offline
post #25 of 26 Old 11-27-2002, 03:08 AM
Cam is pretty small man, makes the numbers more impressive. Are the headers 1 5/8? Did you open up the collectors to the full 2.5" (they come 2 1/4 stock). Little timing and MAYBE a pound or two fuel pressure might have given you 10-15 or so more hp. Couple ideas for ya.
N2O88 is offline
post #26 of 26 Old 11-27-2002, 10:21 AM Thread Starter
1) It is a custom cam from Panhandle Performance
2) No I didn't open the header collector b/c I wasn't sure how it would seal up, but next time they come off they will be opened up.
3) Next dyno pull will be with 18 degrees timing and 38-40 psi of fuel press.
lpmorgan is offline
