build me a 400 hp+ 351W for as cheap as possible - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 11 Old 10-14-2002, 01:20 PM Thread Starter
I know there is an engine guru out there that knows how to build up a 351W. there has to be a good cheaper way of stroking the motor than buying the expensive stroker kits..... I want 400 hp and 450+ torque and I would prefer a lower rpm torque..... How would yall build this?
dangerranger33 is offline
post #2 of 11 Old 10-14-2002, 02:06 PM
Mike Gager's Avatar
400 hp flywheel or rear wheel?
Mike Gager is offline
post #3 of 11 Old 10-14-2002, 02:09 PM
I got 420rwhp and its not stroked. Just alot of compression.
MitStang is offline
post #4 of 11 Old 10-14-2002, 03:28 PM
Shawn95GTRag's Avatar
Re: build me a 400 hp+ 351W for as cheap as possible
392/396 is the cheap 351w stroker. Stroker crank, 351 rods, 302 pistons I believe. Ask your builder about it.
Shawn
'06 Mercury Montego - FWD, 6-Speed ATX, Premier package
'02 Volkswagon Jetta GLS TDI - mods & MPG!
'95 Mustang GT Convertible 5Sp - SOLD
Shawn95GTRag is offline
post #5 of 11 Old 10-14-2002, 03:43 PM
Moonenn3186's Avatar
see my website...
its still in the works but I will be well over 450hp under $3k including heads etc...
N/A of course...
http://home.attbi.com/~moonenn3186/
86 Mustang GT Convertible - 351w
89 Mustang Coupe - blown 331/6 speed
Moonenn3186 is offline
post #6 of 11 Old 10-14-2002, 04:56 PM Thread Starter
so what else did u do for your est 400 hp ..
and arn't u still left with a 351 or am i mistaken?
i would like 400 flywheel hp
this is needed more for overall... more than just some peak hp
post #7 of 11 Old 10-14-2002, 06:01 PM
the cubes stay at 351 yes. This engine is set up for efficency. the longer rod keeps the piston in the combustion chamber longer = a hotter, more complete burn.
This is not set up for peek numbers. This set up will give you a VERY broad tq curve...much like many cubes will do. This just gives you a way a keeping good fuel economy as well...kinda like having your cake and eating it to. It is very streetable.
I am using a custom cam...but you can call Crane and get one very similar. I will be using TFS "High Port" heads. You can go smaller...but I want room to grow.
The only one I have ever seen run used GT40P heads...and he had the flywheel power at 387 and 428 tq...those heads are wicked velocity.
I will be running an Air Gap intake and a 650 vacumn secondary carb for street...with a 800 double pumper for track...
This engine is set up to make great power with limited heads...and even more with big heads...
just a suggestion!
post #8 of 11 Old 10-15-2002, 01:30 PM Thread Starter
that makes since...... any more suggestions....... and what about keeping the fuel injection.....
post #9 of 11 Old 10-15-2002, 01:42 PM
Did you use the 400 ford rods to log rod it?
MitStang is offline
post #10 of 11 Old 10-15-2002, 05:06 PM
Linc's 93 Splash's Avatar
PAW.....?
Hot Rod magazine built a 400 crank/351W block a few years ago using parts from PAW. Maybe you could get a reprint. I don't remember what rods they used - probably 351W rods.
I wonder if PAW offers the kit..you could order it or copy it. I always wanted to build one but never got around to it. Maybe later sometime.
You will need really goood heads.
Good luck!
'93 Splash 5.0 - needs more traction
1997 GT 5-speed with 97 Mark VIII engine swap
Linc's 93 Splash is offline
post #11 of 11 Old 10-15-2002, 07:52 PM
MAT88GT's Avatar
Paul's motor should hit 400hp
351 bored .04" over
dss flat tops
10.something:1
Neil Erickson ported windsor sr heads
comp flat hydro cam
1 3/4" hooker super comps
650 dp
rpm intake
MAT88GT is offline
