NO INJECTOR PULSE 90 5.0 - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 4 Old 05-08-2013, 11:55 PM Thread Starter
I just got my car all together, i assembled it from a shell, went to fire and no starty. figured out i have no injector pulse.
changed ecu relay in pass kick panel and tested circuits before and after relay change and the proper ones seem to be getting 12v. i'm stuck here.
s_blazin is offline
post #2 of 4 Old 05-09-2013, 11:15 AM
87FOX50's Avatar
Trader Feedback: (22)
the connectors at the back of the intake(blk&wht-round), have you tried cleaning the pins/female conn.? also, when you turn on the key can you hear the fuel pump prime? do you have a shop buddy that can help you test voltage at the injectors while you crank it? those 2 round connectors are notorious for corroding up....
347. On3 Single 76mm. TKO. Street Car. Tuned by Willie @ DirtyDirtyRacing.
http://forums.corral.net/forums/members/100249-87fox50-albums-88hatch.html
87FOX50 is offline
post #3 of 4 Old 05-09-2013, 11:18 AM
Spark? With spout in and out?
bender4601 is offline
post #4 of 4 Old 05-09-2013, 12:57 PM
88blk5.0's Avatar
X2 on checking all connectors and especially ground wires. Could be a Bad PIP sensor in distribuitor? I would turn key to run and then use a multimeter to see if each injector plug is getting 12 volts, or put a noid light on each one and spin the distribuitor by hand to see if any light up or not.
88 LX - Street car- 306ci ,Edelbrock Heads/Intake ,FTI Cam,1.6 rr, 30lb Injectors,Cobra Brakes & Rear Disc,Subframes, Eibach Prokit,3.73 gears,T5 Conversion, 10th Anni Wheels 255/40 nt555 Front 275/40 nt555r Rear,Tucked and Smoothed Engine Bay,Complete Por15 Underside
88blk5.0 is offline
