Valve lash settings? - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 11 Old 01-22-2013, 05:51 AM Thread Starter
Im About to start assembly on my 5.0 rebuild and was wondering what to set valve lash at?these are pro comp 210's with a 1.6rr on a 7/16 stud.cam is an x303 if it matters?
I know how to set it i just cant find what to set it at.
GmKilr8 is offline
post #2 of 11 Old 01-22-2013, 06:13 AM
Adam Smith's Avatar
Re: Valve lash settings?
As soon as polylock has finger tight resistance somewhere around another half turn.
sent from Galaxy S3
Modularmisfits.com
83 GT 410ci C4
Gade Race Engines/Team Z Motorsports
Adam Smith is offline
post #3 of 11 Old 01-22-2013, 07:23 AM
Trader Feedback: (48)
Depends on your tolerance for NOISE!. 1/4 turn is recommended for racing(kinda noisy). Anything after that up to 1 full turn is ok. Generally the closer to 1 full turn the quiter.. Pick your poison...
midnightrider is offline
post #4 of 11 Old 01-22-2013, 10:40 AM
Michael Yount's Avatar
Hydraulic roller? There is no lash....
Michael Yount is offline
post #5 of 11 Old 01-22-2013, 04:32 PM
Adam Smith's Avatar
Assuming he meant preload. ..or whatever one refers to it as.
sent from Galaxy S3
Modularmisfits.com
83 GT 410ci C4
post #6 of 11 Old 01-22-2013, 05:18 PM
We know that Michael, but some folks haven't been doing this as long as we have(Eons)..Lol...
post #7 of 11 Old 01-22-2013, 05:25 PM
Cold motor and set it with 1/4 turn pre-load warm motor why not run it and set it until noise goes away then 1/4 turn more. This a hydraulic cam right?
Capri_5.8 is offline
post #8 of 11 Old 01-24-2013, 03:13 AM Thread Starter
Yes its a hydraulic roller anderson B-41 (same specs as a trick flow stage 2)
So when i set this up on the stand what are the exact procedures i need to follow if one of you more experienced members dont mind explaining?
GmKilr8 is offline
post #9 of 11 Old 01-24-2013, 03:15 AM Thread Starter
It will be a mostly street driven car so id like it descently quiet but more than anything i want it reliable which setting is more of a set it and forget it?
GmKilr8 is offline
post #10 of 11 Old 01-24-2013, 11:30 AM
n2omaverick's Avatar
Trader Feedback: (40)
Preload
1/4 turn past zero lash, then set the set screw in the poly lock, then turn both the set screw and poly lock an additional 1/4 turn for a 1/2 turn total. This is what I do on the stand or in the car, cold or warm, hundreds of times.......minimal noise no further adjustments needed!
All hail the almighty B cam! From 175 HP 1985 5.0HO to 1200 HP Turbo cars..........Completely universal, any combo, any goal! B cam or be Slow!
408 internal balance, H beam rods, probe -22cc pistons AFR205's, super victor, custom XFI based stroker cam, 248/258 on a 111 LC. 1.75 hooker super comps, 4.00 gear 9" 4500 converter. 4 wheel power disk brake stock looking 66 mustang weighing in at 2985 with driver!!
n2omaverick is offline
post #11 of 11 Old 01-25-2013, 05:37 AM Thread Starter
Thank you very much sir!
GmKilr8 is offline
