Smog pump removal on 1986 gt 5.0 - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 16 Old 11-22-2012, 11:25 AM Thread Starter
I have a 1986 GT 5.0 Mustang and I am looking to remove the smog pump.
The black valve that is supposed to have a tube on it that runs to the cats is making a ticking noise so instead of fixing it I just want to remove the whole thing.
Would it be better to remove the smog pump and put a idle pulley or is it better to remove and save money and get a shorter belt? I heard the shorter belt will slip on the WP due to the way it has to be ran?
Also, as far as removing the smog pump is there anything else I need?
mrfister11 is offline
post #2 of 16 Old 11-22-2012, 01:04 PM
I just want to point out that's a 10 dollar part at any parts store.
1985 Crown Victoria - carbed 351W, 1 5/8 mustang headers, 2.5" catted exhaust, underdrive pulleys, whitewalls
Boxjohn is offline
post #3 of 16 Old 11-22-2012, 01:06 PM Thread Starter
I want to point out that I run a off road H pipe and have no intentions of ever going to a cat. Also I would like the extra space under the hood to clean it up a bit.
post #4 of 16 Old 11-22-2012, 01:14 PM
Trader Feedback: (18)
I haven't had any issues with belt slippage running the shorter belt on my 86 without the air pump. Just yank off the whole thing, including the air tubing and cap the inlet pipes to the converters and rear head ports. Be sure to leave the tab/tad solenoids at the passenger fender well plugged in and cap the vacuum lines going to the diverter/switching valves, so you don't get any vacuum or exhaust leaks. You may get ecm fault codes, but in 86 the check engine won't show this and the car shouldn't run any different.
408foureye is offline
post #5 of 16 Old 11-22-2012, 01:21 PM Thread Starter
Do you know what size bolts I need?
5/8 in. x 1in.?
Not being lazy or anything but I have to purchase everything offline as I am in the UK and can't just walk into a autozone. So I prefer to order it all online and then do it all once all the parts get here. So if possible what should I order?
post #6 of 16 Old 11-22-2012, 01:27 PM
Banned
5/8 in. x 1in.?
3/4" is preferable, but you could just use a nice thick washer and some red rtv silicone... and yes, its 5/8-11
post #7 of 16 Old 11-22-2012, 03:27 PM
Stangdawg's Avatar
When you remove the smog pump and the plumbing, there are two vacuum lines that can be removed but you need to plug them off. You can also remove the TAB and TAD solenoids behind the passenger shock tower as well. Really cleans up the engine bay.
Once you pull off the plumbing to the back of the heads, you will need to put in two bungs to plug the holes---> 1979-95 Mustang Cylinder Head Smog Plugs for 5.0L & 5.8L at LRS - Free Shipping!
1989 GT - AFR165s - Tmoss ported Cobra - BBK LT headers -XE264-12 cam - WC T5Z and full bolt-ons - 310 RWHP / 332 RWTQ (SAE)
Stangdawg is offline
post #8 of 16 Old 11-22-2012, 05:55 PM
Will removing those relays cause any code issues? BTW I havnt had any slippage problems either. Stock crank pulley and A/C 5060850 (6PK2160) belt.
Stock S/B, TFS170, 1 5/8 shortys 2.5 O/R X Flowmasters/2.5 tailpipes, AFM Powerpipe, 80ProM, 75Accufab TB, 30#inj, PP Typhoon, N41, 3G, MSD 6AL, AOD Baumann kit w/ Sonnax bits, 3K Edge L/U, 3.55, Eibach/Tokico/Mac rear uppers/lowers, 5 lug 17X8 Ford Cobra R's, Nitto 555's.
1989LX3D is offline
post #9 of 16 Old 11-22-2012, 06:22 PM
Stangdawg's Avatar
You will get codes but no check engine light. No impact whatsoever on performance. They are solenoids for the valve (hence why they have the vacuum lines connected to them), not relays.
post #10 of 16 Old 11-23-2012, 03:47 AM Thread Starter
For capping it off you just use those little rubber plugs that go over the tubes?
post #11 of 16 Old 11-23-2012, 03:51 AM Thread Starter
post #12 of 16 Old 11-23-2012, 03:55 AM Thread Starter
And with those plugs, How do they screw in? Will I still be able to get those in with the engine in the car?
post #13 of 16 Old 11-23-2012, 07:32 AM
Banned
absolute worst case scenario... you screw a 1/2" long 7/16-14 bolt into it and thread it in there.
post #14 of 16 Old 11-23-2012, 01:42 PM Thread Starter
Does anyone have a link to the caps I need to plug off the tubes?
post #15 of 16 Old 11-23-2012, 06:23 PM
I use a 5060850 w/stock crank pulley, p/s and a/c. See above post for the alt #.
1989LX3D is offline
post #16 of 16 Old 11-24-2012, 03:50 AM
Stangdawg's Avatar
Are you talking the vacuum lines? Here you go:Vinyl Vacuum Cap Assortment at LRS - Free Shipping!
Every regulate auto parts stores have these too.
