Detailed Vacuum line routing pics for stock 1989 Mustang GT - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 7 Old 11-08-2012, 05:26 PM Thread Starter
Unhappy Detailed Vacuum line routing pics for stock 1989 Mustang GT
Does anyone own a stock 1989 Mustang GT 302 with all smog equipment?
If so, would you be able to post detailed pics of the vacuum lines? They have been moved around, and I know where only a few of the lines go.
I have seen vacuum line diagrams, and I am unable to make heads or tail of them.
Any help would be greatly appreciated
89GTMustang is offline
post #2 of 7 Old 11-08-2012, 08:34 PM
Talking
Here you go:
Veryuseful.com
http://www.google.com/url?sa=t&rct=j...TjcmcZoV5NJ4tA
racerxmdd is offline
post #3 of 7 Old 11-09-2012, 10:11 AM Thread Starter
Unhappy Seen that before. No help
I have seen that one, as well as others. I just cannot make heads or tails of it. I have asked my brother to have a look at it, and he said the same. I really need pics of the left side of the engine compartment, as you look at the engine from the front of the car, that show where the lines route to. The vacuum tree, as well as the lines on the two valves? on the shock tower. I replaced these, after testing them. Also, the line under the intake manifold that runs to the pcv valve. I understand it is easy to improperly route that hose.
Symptom: With the car at idle, or moving down the road, the check engine light comes on. Accelerate, and the light goes out. Decelerate, and the light comes back on. No codes when I do diagnostic. My brother recommended a mech who works for the county, on trucks. He moved lines around, teed lines into other lines, and I know that wasn't right, so I put the lines back to the way they were.
post #4 of 7 Old 11-09-2012, 11:53 PM
stangPlus2Birds's Avatar
On ebay, search for
mustang vacuum manual
You'll find something like
Good Luck!
Joe - 86 Mustang GT with ABS!
M-2300K brakes, Mach1 Springs, D178 rims, and 245/45/17 RE730 tires. Car Pictures: http://www.veryuseful.com/mustang/tech/misc/Mustang1986_with_Mach1_springs/
stangPlus2Birds is offline
post #5 of 7 Old 11-10-2012, 12:15 AM Thread Starter
Stangplus2Birds. Thanx, I'll give it a try.
post #6 of 7 Old 11-10-2012, 12:23 AM Thread Starter
EBay has a Electrical Vacuum Trouble shooting manual. I already have this manual, and it does not show vacuum line routing. It tells how to diagnose vacuum leaks.
post #7 of 7 Old 11-12-2012, 10:12 PM
blownpearlGT's Avatar
Trader Feedback: (23)
just picked up a virgin 89 lx.....pm me what pics you need.
2011 PLatinum 5.0 F150
2008 King Ranch Expedition
1990 Gt Dss 306, afr's,faceplated tko, v2, meth, all tubular ,custom paint. Dez tuned
blownpearlGT is offline
