Catch Can set up - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 12 Old 08-27-2012, 05:58 PM Thread Starter
98snakehorse's Avatar
Catch Can set up
Well I am in major need to install a catch can or two to my stang. I'm currently running 11lbs on my dss 331 engine and am getting a little blow by. I am running breathers on both valve covers with the pcv blocked off. My question is.... Do I need to run two catch cans? Also where do I get the fittings that will go into the holes on my valve covers to go to the catch can? I was just going to run heater hose. I have the popular "Ford Racing Valve Covers" Thanks for any help.
98 Cobra_stock bs/exhaust [SOLD]
2000 s/c gt, 511rwh 450rwtq [SOLD]
1995 331 Turbo Gt, 420rwhp 498rwtq
1998Gt , PI SWAP + Bolts ons (Build in Progress)
98snakehorse is offline
post #2 of 12 Old 08-28-2012, 02:05 PM
M88handles's Avatar
Trader Feedback: (114)
Try this or search "catch can" in the Turbo section
What size catch can lines and fittings?
91 Dove Grey coupe, Tennessee Transmissions Built AOD, 3.73's, BBS RK's, Full Team Z Suspension, H/C/I. V3-SCI, r134 AC/PS/PW/CC
11.71@115mph 1.70 60' foot braking 2300rpm.........................SOLD
"If your broke...or enjoy lowballing and wasting time, your likely on the wrong post"
M88handles is offline
post #3 of 12 Old 08-28-2012, 02:59 PM
FiveLiterFox's Avatar
Trader Feedback: (66)
Read this thread, all you need to know. I even posted part numbers for the whole setup...
Valve cover breather
90' LX, Dart 347/YSi 843 rwhp
FiveLiterFox is offline
post #4 of 12 Old 08-28-2012, 03:34 PM Thread Starter
Great thanks a bunch!!
post #5 of 12 Old 08-31-2012, 12:03 PM Thread Starter
Alright I just ordered the same entire setup as you. Another question... is the breather on the Morosso tank large enough to compensate for both valve covers ventalation?
post #6 of 12 Old 08-31-2012, 02:46 PM
Yes, it's plenty of ventilation. You won't have any issues. Unless of course you have some sort of excessive blow-by. But it would have to be pretty bad.
post #7 of 12 Old 08-31-2012, 04:29 PM Thread Starter
Perfect. Yeah I dont think there is too much blow-by but my vc breather sits right next to my down pipe so whenever I get into full boost it will smoke. Cant have this anymore too dangerous. Thanks for your help the serial numbers you posted made things much easier.
post #8 of 12 Old 08-31-2012, 04:34 PM
mean 5.0 liter's Avatar
Scribing
[95 GT] 351W motor with a Novi 2000 with 11-12 lbs, Victor 5.8, 42 lbs injectors, 80 mm C@L, tko 500, 3.73's.
mean 5.0 liter is offline
post #9 of 12 Old 08-31-2012, 05:51 PM
No problem, glad it helped.
Did you make sure to order two of each hose end (2 straight, 2 90's) and 3 total male -12 bungs? You need one bung for each VC and one to add to the catch can since it only comes with 1 from Moroso.
I think I specified all that in the post but could easily be looked over.
post #10 of 12 Old 09-04-2012, 11:11 AM Thread Starter
Yup I sure did. Parts should be in today or tomorrow.
post #11 of 12 Old 09-17-2012, 11:02 AM Thread Starter
Thought I would post a follow up after I did the install, thanks for all the help.
Thanks, Nick
post #12 of 12 Old 09-17-2012, 12:26 PM
Awesome! Turned out great!
