#1 |
331 stroker build...rwhp/torque 1/4 mile guesses??
I am building a 331 stroker with stock block including girdle. It has steel crank, h beam rods, and Ross flattop pistons. Compression will be around 10:1. I will have old trickflow twisted wedge heads ported (intake runners around 190cc) and a holley systemax intake ported to match heads. 75mm tb with 75mm egr delete. 3 1/2 anderson power pipe with 80mm MA with 30lb injectors. I will get a custom cam from FTI with upgraded valve train. tko500 trans. aluminum driveshaft and 373 gears. It has full drag suspension and is a 1993 coupe. Any guesses on power numbers and 1/4 mile times?? I am trying to get at least 400rwhp but i dont know. Also if there are any weaknesses in my setup let me know...thanks.
| Sponsored Links | |
Advertisement |
#2 |
Trader Feedback: (83)
More gear, and Prly more injector.
Should run good tho.
__________________
91 Fox R.I.P. 347: 1.43 60' 6.78@101.30 1/8th 10.64@127.84 1/4 302 1.59 60' 7.63@88.19 12.06@110.58 http://www.dirtydirtyracing.com |
#6 |
ok i will pm him...and yeah i know im pushing it with the stock block but i got a deal on the short block and its already balanced...idk much about balancing so i cant tell you if its zero balanced or not
#7 |
more gear +1
__________________
347 11.1 flat top piston , xfi 236hr-14 cam,Dart pro1 cnc. victor 5.0 ,30 lbs injectors,pro-m 80 maf , 1.6 roller rocker , bbk 1 3/4 long tube headders , h-pipe , 44 serie flowmaster , torsen 31 spline , TKO 600,centerforce dual-friction |
| Sponsored Links | |
Advertisement | |
| Bookmarks |
Previous Thread
Next Thread
| Thread Tools | |
| Display Modes | |
0 Ford
Linear Mode
