#1 |
Getting 89-93 5.0 soon need mod advice
Hello All sometime in afew days i will be getting a 89-93 5.0 auto. I will have about 6k to spend on mods after selling my current car and paying bills buying the car. Coming from owning an ls1 vette I am not familiar with the 302. I kind of need an idea on what works well so im not waisting money.My goal is to have a fun street car that I can take to the track every now and then. As far as power goes im looking for around 300-350whp It also must be smog legal power as I live in Cali. Here are some things i wanted to do first.
1. suspension kit ( maybe beefed up torque boxes as well if current ones look really worn 2. Torque converter,tranny cooler and Gears (not sure which combo is best for street car) 3. upgraded brakes/ better tires After that I was looking to do engine mods. Some of this stuff ill buy new but if I can get a deal on used parts so be it. IF any one has any suggestions please reply |
| Sponsored Links | |
Advertisement |
#2 |
Trader Feedback: (32)
shop the classifieds here and get more for your money. %% my .02, get some good struts, NO monroe and no kyb. get some good ones, like Koni, better yet go for coilovers. I wish i had done that--would have saved some bucks
__________________
89 lx vert stock block/bore, tw 170's, xe266 comp cam performer intake, 70mm tb, 76mm meter. 3:55's ... constant work-in-progress
#3 |
Sounds like you're serious about handling - add a decent set of weld-in subframe connectors. You've got to stiffen the uni-body to allow any reasonable suspension mods to work well. 300-350 rwhp though the auto while CA smog legal AND do all the brake/suspension work you want to do all for $6k will, I think, be a challenge. Of course, you could always put a used LS1 in it....
__________________
Michael Yount - Charlotte, NC - 82 Volvo 242 - 5.0L, T5Z, 8.8" rear; 2008 Mini Clubman; 2000 Honda Accord |
#4 | |
#6 |
If I did another fox EFI car I would do this-
suspension- 94/95 UPR K member kit- steel C/C plates 94/95 spindles with cobra brakes and 17" 95R's rear control arms- MM lower- stock uppers with new OEM bushings MM coil overs front and rear with adjustable Bilstein struts/shocks Eibach front and rear sway bars rear Cobra brakes rear axle- 3.55 gears- Carbon fiber Tlok clutches full CHE brace 94/95 rear axles Chassis- MM or UPR full length SFC's drive shaft loop motor- Trickflow street heat TW top end kit w/ st.1 cam on the running 5.0 short block under drives, electric fan, 94/95 5.0 3G alt, and an aluminum rad Summit long tubes, with 2.5" summit X pipe (w/ high flow cats for Cali), Dynomax cat back poly mounts trans- lentech built AOD trans w/ manual VB- stall convert matched to engine setup aluminum DS Hurst automatic shifter poly mount body- if GT I'd make a 93 Cobra clone if LX I'd leave it
__________________
83 Mustang GT HCI 5.0 5 speed 71 Dodge Demon BB swap in progress Cooter's Coatings Hudson WI 1-612-867-0725- Don "Harvey" Harvey http://cooterscoating.com/Tell him Zac sent you! |
#7 |
Trader Feedback: (23)
6k
Add a exlplorer intake with the 65mm TB to the stock long block good used single turbo set up or S trim some real valvesprings fuel system and tune Some sticky tires who needs suspension lol Find a good used tremec 3550 set up explorer 31 spline diff and some aftermarket 31 spline axles Dollar for dollar hard to beat a turbo set up on a stock longblock impressive 350-400 rwhp on stock parts.
__________________
70 Charger R/T 440/auto 91 coupe H/C/I 91 coupe stock SOLD 89GT 357W H/C/I, SOLD Last edited by rpmmustang89; 07-29-2012 at 11:37 PM. |
| Sponsored Links | |
Advertisement | |
| Bookmarks |
Previous Thread
Next Thread
| Thread Tools | |
| Display Modes | |
Linear Mode
